Tripple Five Fanatic
Seats -Which one for TF big window
I'm trying to figure out which one to put in the truck.
Both will need modification to the brackets to make them fit. 1. Split bench from a Elco. Pros: Will fit without too much work. Cons: Will need seat belts, no power. 2, Buckets from a Sebring Convertible Pros: Have beats built in, power. Cons: Will need to modify the seat to move the belts holder down. What's your opinion.
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
Re: Seats -Which one for TF big window
just my opinoin but i personally don't like the seats to be higher than the bottom of the window.
#3 | |
Tri5
#4 | |
I'd use the red one, because it will clear the center hump
![]() Quote:
I figured out though that i probably have the backrest adjusted too high... ![]() |
I'll go against the crowd and vote for the Sebring seats based upon the overall direction of your build. Modern seats to go with modern drive train & wheels.
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
![]() Join Date: May 2002
Maybe, it's just me but trucks need a bench seat.
'72 C10 Short Fleet "Praise the Lowered" |
![]() ![]() Join Date: Nov 2008
the red set - gotta have an arm rest to help steady the soda can
I agree with the bench seat and had an original recovered.
Life is too short to drive a boring vehicle. |
Thanks guys for helping make this decision.
Tri5
Certified Car Nut
Don't you put that bench seat in that truck you will not be following your theme and you know it so stop looking for the easy way out.lol Bench seats are fine but not for your truck. The kind of truck you are building you have to come with it man you can't be slacking or settling. Since you are always commenting on what I should be doing, I will tell you what you should do and that is get better seats or chop those buckets seats down so they are below your back window. That's my opinion and I know you did not ask for it but hey I want your truck to be laid man so stick to your theme.
Remember you showed me what you wanted it to look like on the outside, well the interior has to match it. Hey you know me and you knew what I would think didn't you.lol Last edited by Kabwe; 10-05-2011 at 12:59 PM. |
#12 | |
Both you and Dan just could not stay out of it huh! Since you last saw it I've changed my mind about the exterior and going in a different direction so the bench will work however I'll do what I want to and you can only talk about me but that won't stop me...very arrogant of you.lol
Dan, The bench seat would work good but I like how the buckets look after I get them cut down. Now see what you guys are doing, making me rethink what I settled on. Tri5 Quote:
#13 | |
Certified Car Nut
Nope I'm not arrogant I leave that to you. You asked and I gave my opinion now deal with it and get some better seats or cut up the ones you have. That's my opinion and I'm sticking to it. Last edited by Kabwe; 10-05-2011 at 11:35 PM. |
#14 | |
I will look at how much work there will be in modifying the buckets compared to how much work to put the seat belts in because I want to be safe when zooming down the road. Tri5
#15 |
Certified Car Nut
Man I will not even get into that because I really don't want to start that debate.lol
#16 |
Its too bad Kabwe is such a meek, mild person. Almost timid! :>)
#17 | |
Certified Car Nut
I've seen his truck in person and I've also talked to him about his plans for his exterior. All I saying is its got to match. Don't put on tennis shoes with a thousand dollar suit is all I'm saying. |
#18 |
I'm just busting your chops. I saw it too a couple weeks ago. Awesome work and a LOT of work too. And I know you did the clip - again, awesome.
I agree a vehicle typically has a theme and all parts of it need to go with that theme. My theme is extra clean, admirable driver. Using custom made bucket seats with a molded center console; while nice, would be out of character with that kind of theme. Agree? I doubt Larry's settling. Somtimes its a "...forrest-for-the-trees" issue. The build has been going on long enough that it's tough to stay headed in a single direction. Tough not to lose sight of your original plan. |
#19 |
Certified Car Nut
Dan I'm not worried about you busting my chops. I've already put you in the trouble maker section with the other people that find joy at my expense.lol
From the statement you've made you understand what I'm talking about, but I don't make excuses for tri5nerd I just will have fun at his expense like he does at mines.lol |
#20 |
(Dan tip-toeing silently out of the room......)
#21 |
![]() Join Date: Aug 2010
Kicking the dust off of this one... which direction did you go? I am now considering a set of these Sebring seats.
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#22 |
i like the idea of the belts being integrated into seats.
maybe a newer seat out of a 2003 or so chevy? they have built in belts and center consoles...
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
#23 |
So do Trailblazer seats, some full size dodge and F150 extended cab seats, and some really choice BMW convertible seats. The problem is that they all look really big in these small cabs. I almost installed the dodge seats in mine but they didn't look right. I went with a 77 Malibu bench seat and lost the head rests. I had to add some three point belts from a Durango to make them work. I just recovered my seat and need to get it in.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
#24 |
![]() Join Date: Jun 2011
My experience with newer seats in the 55-9 trucks is they are too big. The backs are too tall and the cab tilts forward above the window. The seats sit very upright and not comfortable. Newer seats tend to be designed for the backs to lean back more than the original. Check the seat bottom also. They are generally longer than the original so you end up with your legs almost against the steering wheel. I have 05 suburban buckets in my 57 crew cab and if the cab was original, the backs of the seats would be past where the back of the cab would be.
#25 |
I used bucket seats out of a 1999-2005 Chevy Silverado. The lap belt/shoulder belt was built in. They are both power seats. The good thing is they sit right on the floor and are at the correct height without having to build a frame. Plus the armrests.
