Old 04-14-2003, 10:22 AM   #1
duckdown
Unhappy washer fluid pump
Is there a trick to priming the washer fluid pump? When I go to spray the windshield, I can hear the pump working but nothing comes out. I'm assuming it just needs to be primed because the reservoir was bone dry when I got the truck.
duckdown
1969 C-10
duckdown is offline   Reply With Quote
Old 04-14-2003, 10:26 AM   #2
JimKshortstep4x4
Talking
If you pull the inlet hose off of the washer reservoir, you can inject water into the hose while you try the pump, (a helper is needed). Sometimes it it is the "O" rings in the pump, but my experience has been that the piston leaks. If the piston leaks you will get fluid running into the floor usually from the pump.
Jim
Old 04-14-2003, 10:33 AM   #3
mtdave2
newly minted old timer
mtdave2's Avatar
http://67-72chevytrucks.com/vboard/s...ht=washer+pump
check out that post
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 04-14-2003, 10:49 AM   #4
duckdown
Thanks guys! That was exactly what I needed.
duckdown
