5 hole change overs what did you do with
the rear axles? If you got redrill or change over axles or what, tell what you did. I have change over stuff for my 68 and my first 70 are covered . It is my last 70 that came in last week ,I don't have the rear stuff for it. I have a rolling 76 frame I could get the front and do a crossmember change over.
Re: 5 hole change overs what did you do with
I have real leafs so swapped the entire rearend with the one from the same truck that the front came off of. Had to swap over the shock mounts and bump stops from the '67. Just a couple hours work if you have good welder handy.
I used a 71 rearend.
Posted via Mobile Device |
Well, that is what I did on my 68 GMC and my other 70 that I change both from longs to shorts and 8 hole [GMC] and 6 holes[70 c-10] to 5 . Now I am out of extra trucks to get suspesions off of
Grandpa in the rustmobile...
used a 71 rearend to
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
the boat guy
I got some weld on traing arm mounts and adjustable panhard bar and used the 3.73 posi from the 76 that I used the front suuspension from.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
you can also replace the axles ... I think ECC offers them.
