Old 10-05-2011, 01:10 PM   #1
Blue Tank
Blue Tank's Avatar
noise in 04 front
I liked my 72 burb so much i bought a newer one for a daily driver. 1/2 ton stablitrak,4wd 96k. The PO had the left front wheel bearing replaced a few months back. So when i heard a "pop corn" sound coming from the front of the truck i assumed the right one was ready. When i pulled the wheel and caliper the disc didn't move around like i expected so i put the tire back on for leverage and couldn't feel much if anything. With the trans in neutral and the rt front wheel off the ground you can hear a dry sound that seems to be from the front d shaft, the universals didn't seem loose by hand. The pop corn noise doesn't happen in reverse. The cv shaft felt ok. I changed the front diff fluid and it looked like 100k fluid should, no surprises.
1 Can you feel the hub bearing being loose short of grenade time?
2 Can this be from the spline shaft being dry in the t case? I see GM has a special lube for this.
Blue Tank is offline   Reply With Quote
Old 10-05-2011, 08:00 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: noise in 04 front
ttt
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 10-06-2011, 08:31 AM   #3
Blue Tank
Blue Tank's Avatar
Help the illiterate, what is ttt?
69 Camaro 454 6spd/ 1st car and still have it
67 Chevelle 396 Convertible
57 GMC 1/2 t
56 GMC Napco Panel civilian defense
65 GMC v6 long panel
72 Burb
Old 10-06-2011, 09:43 AM   #4
1990SSchevy65
1990SSchevy65's Avatar
TTT = To The Top. Sorry I am not sure about your question either, because on my 1500HD the driver side bearing just went south without warning.
2003 Chevrolet CCSB 4x4 1500HD Mine
2011 Toyota Corolla S Wife's new ride
2002 Pontiac Grand Am SE2 Wrecked/Totaled 2014
1990 Chevrolet 454SS GONE 02/26/11
1991 S10 SCSB GONE 12/24/08
1965 Chevrolet LB GONE 06/06/05
GM for life
1990SSchevy65 is offline   Reply With Quote
Old 10-06-2011, 04:20 PM   #5
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
To me it sounds like a CV joint is bad causing the poping noise. You wouldn't be able to inspect them without removing the boots.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 10-07-2011, 06:43 AM   #6
Blue Tank
Blue Tank's Avatar
Th CV does make sense. The service report noted that the left bearing was really bad. Inside of the wheel is sprayed with rust which must have came from the carnage, maybe it damaged the joint. The noise telegraphs around so it's not easy to pinpoint.
Can you remove the stock boots for inspection and then replace them?
57 GMC 1/2 t
72 Burb
Old 02-15-2012, 09:28 AM   #7
truckdude239
truckdude239's Avatar
Glad you got it fixed!
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
