10-05-2011, 05:54 PM | #1 |
High beam indicator
Noticed on my friends 72', His high beam indicator on the dash was a round light. My 68 panel and 70 blazer have a thin rectangular light. Was that a 67-70 thing? Is the round lamp a 71-72 thing, or 72 only?
10-05-2011, 06:29 PM | #2 |
What?
Re: High beam indicator
My '68 is a round one, and my '70 is a rectangle.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
10-05-2011, 07:34 PM | #3 |
Mmmmnnn, getting interesting now, anyone else' input? thanks Chris.
10-06-2011, 07:08 AM | #4 |
70. rectangle
10-07-2011, 07:52 PM | #5 |
High beem indicator means shes cold gentleman would offer her his coat or other ways to get warm. Yea might could have resisted but didn't feel like it.
10-08-2011, 12:43 AM | #6 |
My '70 has a round one.
10-08-2011, 02:29 AM | #7 |
I seem to recall buying a 68 cluster for parts and it having a round red indicator. It caused me to fail the annual inspection and I had to swap the speedo with the rectangular blue one from the 72.
The truck is titled as a 72 so at some point apparently the feds decided to standardize on a blue indicator. just to add a bit of color to the conversation... |
10-08-2011, 01:30 PM | #8 |
fAILED
10-08-2011, 01:32 PM | #9 |
failed inspection because of a high beam indicator??? What freaking state do you live in. Ive never heard of anyone evening checking to see if there is a indicator on a vehicle. Got ot be a joke.
10-08-2011, 04:38 PM | #10 |
Texas
Its completely true. They failed it for the color. |
10-09-2011, 07:51 AM | #11 |
its all about the +6 inches
I had found a rectangular blue one in a junk yard once... but all my trucks (to include my 72 burb) came with red.
When I lived in texas, I found myself having to educate inspection stations on an anual basis. |
10-10-2011, 07:59 AM | #12 |
67GMC & 70 chevy both round red indicators, both original clusters i would think. My 72 monte is blue.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
09-17-2013, 12:22 PM | #13 |
I have a 68 and it is rectangle. it does not work or if it does it is to dim to see it. I am doing a little project today putting a 8mm blue led right under headlight switch so when high beam is on there will be no dought its working. I also did same thing with blinkers except using green.
09-22-2013, 12:29 PM | #14 |
I had a '67 a long time ago, and I coulda swore it was bow tie shaped. Maybe the PO did that with a little file.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
09-22-2013, 03:20 PM | #15 |
Cluster King
That brings up a very good question and I am not sure what the answer is.
My 72 Cheyenne has a round one and I am pretty sure it has the stock cluster. I have 10 samples in my inventory. 8 are round and 2 are rectangular. I am interested to know more about this too.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
10-08-2013, 03:36 PM | #16 |
My 72 has a round red indicator. The guys at the Jiffy Lube doing the inspection were too distracted by the overall look of the Burb to care what color the indicator was lol.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
10-08-2013, 04:45 PM | #17 |
My '71 truck has a round red one.
Maybe they used both and just threw in what they wanted to?
71 K20 64 GMC mud truck |
10-08-2013, 10:24 PM | #18 |
To my knowledhe it was red rectangles until 71, blue dots up from there.
10-09-2013, 09:35 AM | #19 |
like I posted earlier, I installed two 8mm green led lights and an 8mm blue light in my cluster for my blinkers and blue for high beam indicator. The factory indicators are very dim and barely visible. The only problem is when I use either blinker as green led blinks with the turn is made , well the high beam blue led also blinks. I am not sure why. Is it possible that I have a wiring problem?
10-09-2013, 01:16 PM | #20 |
I would say yes. It sounds like your using the same ground. When you turn the high beam on,do the turn light indicators come on?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-09-2013, 04:58 PM | #21 |
yes I tied all three led lights together in to one ground. should I separate each one to its on ground? will doing this let each light only work without making high beam come on?
