Old 10-06-2011, 05:03 PM   #1
crazeetxn
crazeetxn's Avatar
Carb spacer purpose?
Don't know when the last time I changed it was, but the gasket between the carb and the spacer is leaking.
What advantages do I have with the spacer? I have a Holley 600 on an Edlebrock intake on a stock 350. It's a daily driver. Would it hurt to remove it? I'd have to check and make sure the throttle and choke don't hit the intake, but other than that, is there an adv/disadv?
Thanks for the info!
crazeetxn is offline   Reply With Quote
Old 10-06-2011, 05:32 PM   #2
McSwine
McSwine's Avatar
Re: Carb spacer purpose?
I put on one mine to help with a hot start problem.
McSwine is offline   Reply With Quote
Old 10-06-2011, 06:46 PM   #3
notyo_cheez
Keep it, as McSwine said it will prevent vapor lock from hot fuel. Just replace the gasket and call it done.
notyo_cheez is offline   Reply With Quote
Old 10-06-2011, 06:48 PM   #4
Goldfinger
Goldfinger's Avatar
It's supposed to help throttle response and fuel atomization
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 10-06-2011, 09:40 PM   #5
85burb
85burb's Avatar
I would keep it. I put one on my burb and i could really tell the difference. It helped with low end and response a lot. Mine was a 1 inch 4 hole type.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 10-06-2011, 10:40 PM   #6
85Bowtie
85Bowtie's Avatar
Suppose to.....
A spacer by itself is pretty much pointless, comparative to something the ricer crowd would "mod" their car with.
An insulator on the other hand (which by default will "space" your carb higher) works well to prevent vapor lock and aid in hot starts.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 10-06-2011, 10:59 PM   #7
tucsonjwt
x2 helps with vapor lock and hot starts. Could be to convert generic carburetor to spreadbore intake manifold. Does cause snorkel tube to exhaust manifold and throttle linkage to not line up, so I don't use one.
tucsonjwt is offline   Reply With Quote
Old 10-06-2011, 11:12 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 85Bowtie View Post
Suppose to.....
A spacer by itself is pretty much pointless, comparative to something the ricer crowd would "mod" their car with....
Actually it has been tested with proven results. A 1" spacer on a low to medium rise intake will improve low end torque. Not as much as an NOS or Type R sticker but it will make a noticeable improvement.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-07-2011, 09:20 AM   #9
ymerej71
ymerej71's Avatar
Now that's funny stuff right there! Hahaha!
ymerej71 is offline   Reply With Quote
Old 01-06-2012, 08:43 PM   #10
twouvakind
twouvakind's Avatar
I know there is a gasket from carb to spacer, is there supposed to be one from spacer to air cleaner?
twouvakind is offline   Reply With Quote
Old 10-07-2011, 08:55 AM   #11
crazeetxn
crazeetxn's Avatar
*Note to self*
Keep the spacer and replace the gasket!
Good info ya'll. Appreciate the help!
Old 01-06-2012, 08:53 PM   #12
kris's66lwb
resident wrencher
Two of a kind i beleive there talking about a spacer undernethe the carb to space it from the manifold not one to space the air cleaner from the carb thos gaskets are not nessacerry but they have them anything above the top plate of the carb does not have to be sealed because it should be metered air going thru the venturis any thing below the throttle plates needs seals to keep leaks away aka un metered air
kris's66lwb is offline   Reply With Quote
Old 01-07-2012, 10:39 AM   #13
twouvakind
twouvakind's Avatar
Oh, my bad. Thanks. I'll create a new post regarding my spacer questions.
