Old 10-08-2011, 07:57 AM   #1
DugJones
wiring assistance
For the past year I have been slowly putting my 71 Blazer back together and I am now at the point where I am running a peerless wiring kit, but have run into an issue. I have these two relays (?) on the drivers side firewall behind the brake booster that I cant identify and don't seem to have any left over wires to run to them. Can anyone tell me what these are and let me know if I missed a step somewhere? Thanks
DugJones is offline   Reply With Quote
Old 10-08-2011, 05:22 PM   #2
bigbadchev72
People know me
bigbadchev72's Avatar
Re: wiring assistance
One is the horn relay, Not sure about the other
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 10-08-2011, 06:11 PM   #3
48richard
48richard's Avatar
I believe they are part of the TCS (Transmission Controlled Spark) system. This was an emission control system that somehow limited the spark advance unless the trans was in high gear (I think). The harness connects to the transmission and to a vacuum actuator by the carburetor. Most people seem to have removed all this.
I don't think it's the horn relay - that's on the inside of the cab.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 10-09-2011, 06:49 AM   #4
DugJones
Sounds good. I will remove them and see what happens. Thanks for the help.
