Old 10-08-2011, 06:09 PM   #1
bigdogboxers
bigdogboxers's Avatar
Drive line
Does anyone local have a 1960-66 chevy or gmc drive line for a shortbed automatic (small block 350 with turbo 350 tranny) or can I get info on one that will work from another vehicle... I am Fabricating a tranny cross member and haven't drilled the holes for the motor mounts yet... Or can I get the measurements for a stock drive line.
bigdogboxers is offline   Reply With Quote
Old 10-08-2011, 06:31 PM   #2
Vernski
Re: Drive line
Bigdog I have a 63 chev swb and live in Rathdrum it has a I6 w/granny gear 4sp you would be welcome to measure it if you like...Vernski
Vernski is offline   Reply With Quote
Old 10-08-2011, 07:47 PM   #3
sigshooter
sigshooter's Avatar
Re: Drive line
using the original motor mount holes the driveline should be 57 1/2 inches overall (outside of cup to outside of cup ) of course you will have a yoke that goes in the tranny on top of this but the driveline will be 57 1/2 total length 350/350 combo
sigshooter is offline   Reply With Quote
Old 10-09-2011, 12:08 AM   #4
Captainfab
60-66 Nut
Re: Drive line
I would just get one that is a little too long. It doesn't cost that much to have one shortened. There are several places around here to get that done. That way you have one the exact length you need. That makes more sense than moving the engine and trans to accomodate the driveshaft. Check Garwood Wrecking, they should have some to choose from.
Old 10-09-2011, 12:04 PM   #5
bigdogboxers
Re: Drive line
Thanks guys I guess I will need to get to garwood and pull and
save.
