Old 10-10-2011, 05:13 AM   #1
Dude68
Active Member
1968 chev swb
Just hauled in my 68 that was purchased new in 68 . He had an engine exchange as well as a transmission exchange, otherwise I am all original. Now I have had this truck parked since the timing gear broke. I tore into it pulled the head a nd took it with me to have the gear pressed on the cam and head redone. Long story short head was cracked nobody could match my motor with a head so the truck sat in my driveway until I moved a few months later. And of course I moved to a neighborhood that did not allow stalled vehicles or projects In the driveway. So the truck was sent to a friends where it has been for 16 yrs. But I got it yesterday and it is in my dads new shop. So my dilemma is do I try to fix thie exchanged motor, that appears to be a 235, or put my 350 in there that I rebuilt a few years ago for running a dirt track car. If I go with the 350 I would like to change to an automatic trans as well. .???
Dude68 is offline   Reply With Quote
Old 10-10-2011, 10:27 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1968 chev swb
I guess if I had a 350 on hand and a broke six cyl in the truck I would use the 350 as long as it wasn't too radical. Just get a th350 auto trans and put in at the same time.
LockDoc
Leon
Old 10-10-2011, 10:36 AM   #3
faribran
Re: 1968 chev swb
i vote 350, i did this swap out a few years ago.... have not missed the 6 cyl.. u will be glad u did..
faribran is offline   Reply With Quote
Old 10-10-2011, 01:34 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: 1968 chev swb
My vote is the 350 also since the truck isn't stock anyway (235 engine).
You need to check your rear end ratio. A lot of those sixes used a 4.11 or lower ratio and your truck will rev pretty high going down the highway with the 350. May need to change to a friendlier ratio or go with an overdrive trans.
68gmsee is offline   Reply With Quote
Old 10-10-2011, 06:26 PM   #5
jay6891
Car Knocker
jay6891's Avatar
Re: 1968 chev swb
put the 350 in and a 700r4 and you will love it! And welcome from a little south of ya in Jefferson AR!
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 10-10-2011, 09:56 PM   #6
Dude68
Active Member
Re: 1968 chev swb
Is 700 r4 an overdrive transmission? What kind of steering column will it need?
Old 10-10-2011, 09:51 PM   #7
Dude68
Active Member
Re: 1968 chev swb
Its a 4:11 positrac rearend. I like the three speed, but think an automatic will work better.
Old 10-10-2011, 09:53 PM   #8
Dude68
Active Member
Re: 1968 chev swb
Does anyone know which mirrors were stock on this truck, round or square?
Old 10-11-2011, 11:17 AM   #9
faribran
Re: 1968 chev swb
yes, it is an overdrive... and a stock column will work...
Old 10-16-2011, 12:51 AM   #10
faribran
Re: 1968 chev swb
67 & 68 exterior mirrors were round
