Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Idiot lights to gauges
Can anyone tell me what all is needed to swap my 78 Scottsdale from warning lights to gauges? Links would be killer too if possible. Thanks.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#2 | |
Re: Idiot lights to gauges
John 82 Chevy Silverado 350ci/TH350 ![]() |
http://67-72chevytrucks.com/vboard/s...d.php?t=452340
This thread has a lot of good info if you want to re-pin your stock harness. Seems easier to me than swapping harnesses behind the dash. Hope this helps!
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
I did this conversion on my 80, I re-pinned the connector.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
I figured the cluster and senders!
#6 | |
Moderator
Found it in the FAQ. http://67-72chevytrucks.com/vboard/s...51&postcount=2 Last edited by hatzie; 10-11-2011 at 08:30 AM. |
Sweet, thanks.
Slots go on anything!
I have a wiring diagram from my '79 I think I may be able to scan for you. Worst case, they are really cheap (around $10) on ebay. That's where I got mine, and it saved my rear.
1974 Jimmy- 5.3/4L80e/NP241 |
