10-10-2011, 08:20 PM | #1 |
Cruise Control from '72 Suburban
Just pulled out of my suburban tonight...
A.R.A Speed Controls prt# 6497417 Comes with everything pictured. Including the original owners installation manual (10 pages), warranty/registration paperwork, & troubleshooting guide. Also comes with the Servo, throttle cable, throttle extension, 54" speedo cable, wiring harness, brake relay, servo mounting bracket, nuts, and bolts for mounting. Only thing I don't have is the controller turn signal lever. Find one and it plugs right into the included wiring harness. Also comes with vacuum hose and tee that plug into brake booster hose. Asking $400 shipped to the lower 48 priority mail. *******PRICE WILL DROP UNTIL SOLD********* I haven't tested the unit. This style you disconnect your stock speedo, plug into the servo. The included speedo cable goes from the servo to the back of your speedo in the dash. Run the throttle cable to the carb. Plug in the wiring harness to the servo, ground the servo. Run the other end of the harness inside the cab. Plug into fuse block. Tie into existing brake wiring switch. Plug signal control into harness. Any questions please ask. Thanks Last edited by Sweet 72; 10-14-2011 at 09:53 PM. Reason: price |
10-10-2011, 08:27 PM | #2 |
Re: Cruise Control from '72 Suburban
few more pics.
