Old 10-12-2011, 02:23 PM   #1
webfoot
1971 K-20 HO52 brakes & bearings
Going to try and do wheel bearings/seals this weekend. I replaced the shoes once but I'm sure I did not get the right size because I got whatever the parts store came up with. I think I need the 11 5/32 x 2.34" drums but want to confirm. If it matters this is on a 4wd.
Also, there are 2 bearings/seals per hub, correct?
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 10-13-2011, 10:30 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 1971 K-20 HO52 brakes & bearings
ttt- anyone?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-13-2011, 11:46 AM   #3
k2rm
k2rm's Avatar
I can't comment on the drums since I swapped to disks on my HO52.
There is an inner hub seal that goes around the spindle. There is an outer axle flange seal.
There is also an inner and outer bearing, each held in by bearing races. Here is a link to a previous discussion on how to remove the bearings and races.
http://67-72chevytrucks.com/vboard/s...93#post4874893
k2rm is offline   Reply With Quote
