Old 10-14-2011, 12:22 AM   #1
Arl37
Correct headlight for 69 C10
I purchased a Sylvania H6024 from ORiley for my 69 C10. The lugs on the mounting bracket don't match the lugs on the headlight unless I turn the head light 90 degrees and then the vertical lines on the headlight, are no longer vertical. I don't hink this is correct. Any help would be appreciated.
Arl37 is offline   Reply With Quote
Old 10-14-2011, 12:51 AM   #2
omodified
omodified's Avatar
Re: Correct headlight for 69 C10
You can check out my build thread where I show my Sylvanias installed. I used 6024ST. Maybe your buckets are installed on the wrong sides?
Board Member #87725
Old 10-14-2011, 02:29 PM   #3
Arl37
That was it,. Buckets on the wrong side. Thanks omodified. Must have been a senior moment on my part
