Old 10-14-2011, 10:30 AM   #1
NPilot1975
NPilot1975's Avatar
Cab width pinch weld to pinch weld?
Does anyone have the width of a 67-72 truck cab from the rocker pinch weld to rocker pinch weld? I found that the cab is 6' 6" wide, so assuming the width would be around 5' 10" or so???? Any help would be appreciated!
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 10-16-2011, 05:03 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Cab width pinch weld to pinch weld?
ttt- anyone?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 10-16-2011, 06:14 PM   #3
crazy longhorn
Fabricate till you "puke"
If your cab is on the frame....measure from the pinch weld, to the outside of the rail(both sides)....take those figures, & add 34" for the width of the rails. That should get you within a fraction of an inch crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-16-2011, 08:17 PM   #4
NPilot1975
NPilot1975's Avatar
I was at work when I posted it. Measured it this weekend and believe it was 6' on the dot. Read another post that said the cab was 6' 6" and the rocker measured 2.75" - 3".
