Old 10-14-2011, 02:32 PM   #1
Rochlow
Dropmember and turning
So I ordered a drop member for my blazer and I was wondering for those you guys running one is, since the crossmember narrows the track width can you make turns with the tire and wheel still tucked in the fender.
I am running a 15x7 wheel with a 235/60/15 tire with like a 3.5" backspacing. Later, on I'd like to run a 20x8 wheel with a 255/35/20 and a 4.5" backspacing. However, I don't want to have to air the truck up to the point it looks like a donk when I drive down the road.
Rochlow is offline   Reply With Quote
Old 10-14-2011, 02:44 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Dropmember and turning
You will be able to turn lock-to-lock at ride height (~6"), tires/whels tucked, without airing up 'donk style'. The trade off here is that the rack & pinion doesn't turn as tight as your current box, so the wheels don't contact the fenders...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-14-2011, 02:50 PM   #3
Rochlow
Thanks Gringo.. Good to know.
When I drove it down the block with my son this is where we had the ride height.
Old 10-14-2011, 06:04 PM   #4
csa daddy
csa daddy's Avatar
Back needs to be lower
csa daddy is offline   Reply With Quote
Old 10-14-2011, 06:39 PM   #5
Rochlow
Just a flip of the switch..
Old 10-14-2011, 09:55 PM   #6
YBNORML
YBNORML's Avatar
Looks great! Kinda makes me want to give up on my shortbox project and use all the goodies on my blazer instead
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-15-2011, 12:39 AM   #7
Rochlow
You should do it!! Driving low and topless!
Old 10-15-2011, 01:48 AM   #8
YBNORML
YBNORML's Avatar
To tell you the truth, it has crossed my mind before. If I didn't have such an emotional attachment to the shortbox, it was my first vehicle. It would probably already be underway. Luckily my blazer is quite low. Eventually I will go a little more extreme.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-15-2011, 08:34 AM   #9
barnold
barnold's Avatar
Very nice!!! I am building a blazer now. Where did you mount your air tanks and what size are they?
barnold is offline   Reply With Quote
Old 10-15-2011, 08:44 AM   #10
Rochlow
3 gallon under the body behind the rear wheel.
Old 10-18-2011, 01:30 PM   #11
n2billet
Village Idiot....
n2billet's Avatar
This is where I'm driving at the moment, you have to be careful turning sharp corners or it will "touch" the fender. I have driven it lower but at this height I can drive it without to many worries. Hope this helps you....
http://67-72chevytrucks.com/vboard/s...351837&page=44
post 1092
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 10-18-2011, 01:40 PM   #12
Rochlow
post 1092
Thanks.. That gives me alot to think about and maybe going with a larger diameter wheel.
Old 10-18-2011, 03:13 PM   #13
tubbedII
needs more $$$
tubbedII's Avatar
post 1092
Awesome! How's the ride at that height, and what's your PSI?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-18-2011, 05:50 PM   #14
n2billet
Village Idiot....
n2billet's Avatar
The ones I have are 20x8.5 with a 255/40/20 it's 28 inches tall.
It rides awesome! I don't know the PSI, I'm using AccuAir and the system doesn't use gauges.
