Old 10-15-2011, 08:01 PM   #1
sigshooter
sigshooter's Avatar
Frame painting advice needed
I have my frame stripped down, and I am ready to paint. I am wanting a daily driver not trailer queen. I steam cleaned the frame and it has no grease and light surface rust with alot of the factory paint still on.
My question is, I will probably spring for the 100 bucks to blast the frame and would like to paint vs powdercoat due to the price difference. What paint should I use that won't peel and rust thru? Looking for an economical way to get a good finish for a driver. Looking for someone who has used the product they will be recomending.
sigshooter is offline   Reply With Quote
Old 10-15-2011, 08:13 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Frame painting advice needed
I've used a variety of paints including POR-15 and Zero Rust with mixed results. If I went to the trouble of sandblasting a bare frame I'd shoot it with epoxy primer and spray it with catalyzed acrylic enamel. It's a relatively inexpensive option that is very durable.
The best job I've ever done was my 46 Ford back in the 1980's. I primed it with Corroless primer and shot it with catalyzed acrylic enamel. 8 years and 300,000 miles later it still looked fantastic.
Old 10-16-2011, 03:34 PM   #3
bama63
bama63's Avatar
ppg has a line of catalyzed alkyd enamel for heavy equipment and commercial use called alk-200, i have used this on a ton of heavy equipment and man is it tough and also very resistant to sunlight and chemical cleaners and this is also a direct to metal paint no primer required, comes in pretty much any color you can dream of. i picked up some last week for a lift truck at work cost $42.00 a gal for the red ready to spray right out of the can
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 10-16-2011, 07:14 PM   #4
sigshooter
sigshooter's Avatar
I have read alot of threads on this and other places online. I think I will go with Tractor Supply's Equipment primer and paint. I will use the catalyst/activator and have the frame sandblasted.
If any has had a bad experience with this please let me know. The paint is reasonably priced @ 23 bucks a gallon and the convience of being able to get what ever I need locally instead of having order everything from Eastwoods or the such. They also have this paint available in a spray can for those little pieces. I bought a spray can today of the satin black and did a test piece, looked just like the sheen I am after.
Thanks to all you have given their input
Old 10-19-2011, 02:04 PM   #5
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by markeb01 View Post
I've used a variety of paints including POR-15 and Zero Rust with mixed results. If I went to the trouble of sandblasting a bare frame I'd shoot it with epoxy primer and spray it with catalyzed acrylic enamel. It's a relatively inexpensive option that is very durable...
That is basically what I did recently for my frame below.
Post up some photos of the painted frame, when you get a chance.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-19-2011, 04:54 PM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Frame painting advice needed
I always use Rust-Oleum Protective Enamel (or)
Rust-Oleum Professional High Performance Protective Enamel.
Sold at Lowes and Walmart.
Which ever is available mixed with a little bit of gasoline. (Brushed) or (Rolled)
No primer. The gasoline is being used as a catalyst & hides the brush marks.
Gasoline is a petroleum bi-product which works well with the Oil Based Rust-Oleum.
It dries very quickly this way!
For Touch-ups I use the rattle cans.
Every bit of black paint on my truck is Rust-Oleum Oil Based Enamel.
Rust-Oleum (Stops Rust) Protective Enamel is the No. 1 rust-preventive paint available.
Rust-Oleum (Professional) High Performance Protective Enamel
is ideal for metal surfaces in heavy-duty and commercial environments.
They also carry Rust-Oleum Professional Undercoating & Truck Bed Coating.
http://rustoleum.com/CBGProduct.asp?pid=150
http://www.rustoleum.com/CBGResourceCenter.asp?sn=fa2
http://www.youtube.com/user/RustOleumAutomotive
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
