Old 10-15-2011, 10:23 PM   #1
forestb
forestb's Avatar
side window felt channel bracket
There is a bracket that holds the felt channel on the back side of the side window to the back edge of the door. It is bolted to the back edge of the door where the bottom of the window starts. The nut on the bracket broke off. Does anybody sell these brackets? Or do I have/get to go to a wreaking yard?
forestb is offline   Reply With Quote
Old 10-15-2011, 10:40 PM   #2
'63GENIII
'63GENIII's Avatar
Re: side window felt channel bracket
Can you wel it back on? I know that wher mine bolted to the door, the metal fatigued and I had to weld the door. It's held so far. Not too sure about nut on the bracket though. I'd be looking at wreckers if you want another bracket.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-15-2011, 10:49 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
I "might" have a set, but will have to look.
DPowers is offline   Reply With Quote
