Old 10-16-2011, 01:29 PM   #1
mikewarme
72 drag link
Does anybody have ideas where I can buy a drag link for a 72 c10? Long story short doing a 67 swb truck. Frame and suspension is powdered black and I put 72 knuckles and disc brakes. Know I need to do steering and are wondering if there are any cool parts out there.
NO CHINA PARTS ON MY TRUCKS!
mikewarme is offline   Reply With Quote
Old 10-16-2011, 07:27 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: 72 drag link
You cant get that centerlink aftermarket, its a no wear part. If its bad, its cause it was bent. I think you can look in the boneyards in the 73 up trucks & find what you need....note the diffs in 71-72, on the 1/2ton. The 73up 1/2 tons did have rubber bushings in the A arms, but straight From bell tech. The Q I asked, was installing 73 up dropped spindles on my 69, (that already had 71 suspension under it). "The upper ball joint, & the outer tierod need to be replaced, to fit the later spindle....the rest of the parts work". the difference is in the taper on the top ball joint, & the outer tierod end. If I missed anything, one of the "brothers" will pick it up. best of fun,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
