Old 10-16-2011, 04:30 PM   #1
SFTorange
SFTorange's Avatar
Windshield Washer Pump Replacement
Hi All,
I just finished installing a new windshield washer pump, and I thought I'd share what I did with everyone. I'm really happy with how it turned out.
I had mixed results with an attempt to rebuild my original washer pump. It quit working after just a couple of uses, so I tried a replacement original pump from Orielly's with the same result.
Fed up with the old-style mechanical pump, I decided to see what kind of electric pump I could find at Napa. After a bit of working, my parts guy and I found this part number 60-300 replacement electric washer pump that is designed to do exactly what I was trying to do.
I bent up a bracket similar to what the original pump sits on.
After a bit of black paint and a couple of screws, I was all set. The new pump hooks right into the original wiring and works perfectly. The replacement pump comes with the necessary fittings to plumb right into the exisiting hoses from the original pump. Now I have a powerful, reliable washer pump, and the cost came in just under $20.
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 10-16-2011, 05:17 PM   #2
Woogeroo
Re: Windshield Washer Pump Replacement
That is awesome tech... thanks a lot for taking the trouble to document and share with us.
I know how time consuming just one little article can be.
Thanks!
-W
Woogeroo is offline   Reply With Quote
Old 10-16-2011, 06:23 PM   #3
TR65
TR65's Avatar
Thanks SFT!!
Now I might have washers again.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 10-16-2011, 09:05 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Excellent. Thanks for sharing.
Old 10-16-2011, 09:41 PM   #5
T Smith
T Smith's Avatar
Another thanks! Pictures are worth a thousand words!
The PO of my truck took out the hoses, nozzles, and everything so I've really got to start from scratch.
T Smith is offline   Reply With Quote
Old 10-16-2011, 09:45 PM   #6
SFTorange
SFTorange's Avatar
Thanks!
-W
Originally Posted by TR65 View Post
Thanks SFT!!
TR
Thanks everyone, I'm just glad to be able to contribute to the site!
The Brown Truck
Old 10-16-2011, 10:24 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
awesome ! great tech , thanks
Old 10-17-2011, 11:59 AM   #8
dracko
dracko's Avatar
Thanks! I was just searching around wondering what pump would be a good fit. Perfect timing!
Any idea if it'll be a pain to wire up if the truck never had washers to begin with? I already mounted up the washer fluid reservoir/tubing/sprayers and have the knob with the push button.
dracko is offline   Reply With Quote
Old 10-17-2011, 02:44 PM   #9
SFTorange
SFTorange's Avatar
I can look at my wiring, but I can't imagine that it will be hard. On my truck there's a 12V ignition source that comes off of the windshield wiper motor. Your truck might even have the correct terminal on the motor for it. I believe that the push button on the switch simply completes the circuit by creating a ground.
Let me know if you need more help.
The Brown Truck
Old 10-17-2011, 01:20 PM   #10
jimmydean
jimmydean's Avatar
Nice work, I now have another under the dash project. Thanks.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 10-17-2011, 02:45 PM   #11
SFTorange
SFTorange's Avatar
It's nice to have on one that costs 20 bucks and takes less than an hour to complete!
The Brown Truck
Old 09-17-2012, 01:17 PM   #12
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
The original wiring connector for the washer pump has double yellow and dark blue.
On the Napa Part, with what looks to be a pink and black lead, which goes to which?
I'm gonna guess: The yellow on the connector goes to the pink lead, and the dark blue on the connector goes to the black lead. Right?
I'm going right now to Napa to try for this part. Going to follow your tech EXACTLY. Thanks much.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 10-01-2012, 12:39 AM   #13
1972SUPERSB
1972SUPERSB's Avatar
Please let me know if this works. I want to do this on my truck next. Just wanna know what the easier way to wire it up will be.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 08-10-2014, 07:37 PM   #14
davepl
davepl's Avatar
Not with AC! I'm working on this now and it took me at least 2 hours to remove the HVAC controls, ashtray, radio, oil pressure line, vacuum line, headlight knob, cluster, and most of the AC pipes.
On a non-AC truck I think just the radio would do it. Or the cluster.
My point being that if you ever have easy access to this area and want reliable washers, do it when you have access!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-01-2012, 03:42 AM   #15
jjzepplin
jjzepplin's Avatar
So does this work just like the original? Or do you have to hold the wiper button to spray. Lets see them a sprayin..just sayin
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-01-2012, 05:53 AM   #16
huahuamick
huahuamick is offline   Reply With Quote
Old 10-01-2012, 08:53 AM   #17
CRGRS 66
CRGRS 66's Avatar
saving this in my electrical folder, thanks for sharing!
funny, I hear my pump running when I press the button... but the PO discarded the washer bottle so I don't know if mine actually works or not. Even if it does, this is a good upgrade. I won't even bother with the old one.
Thanks!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 09-10-2013, 01:06 AM   #18
DkOlive72
DkOlive72's Avatar
Hey folks,
I just did the same mod recommended here, using a trico pump from O'Reilly Auto, but instead of building a new metal piece, I stripped off all of the old parts of the original pump and mounted the universal pump to the original metal plate. I also soldered the wires to the original terminal (after disconnecting and stripping off all of the windings from the solenoid). Sorry the pic isn't the best.
DkOlive72 is offline   Reply With Quote
Old 09-10-2013, 12:19 PM   #19
1966shortwide
I just mounted a pump from oreilly's next to washer reservoir and wired it to work with push button on wiper switch so it ground's motor to run, run's on high and low speed on wiper's when pushing on switch button. Plumbed hose from reservoir to pump and then to squirt nozzle's . i removed all other hoses routing to factory pump . i left factory pump mounted as it did not work anyway.
1966shortwide is offline   Reply With Quote
Old 09-10-2013, 01:10 PM   #20
lasher78
lasher78's Avatar
any pics of how wired to factory push button knob?
live like you are dying
lasher78 is offline   Reply With Quote
Old 08-10-2014, 08:34 PM   #21
Snailed
Snailed's Avatar
I used on of those universal Trico pumps too. It worked OK but I killed it accidentally. I replaced it with a used, stock pump from a 2005 GTO. The pump was smaller but it sprays MUCH stronger which is nice to blast snow and dirt off.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 01-31-2016, 05:37 PM   #22
Sturvin
I know I am resurrecting an old thread here, but fun fact:
If you remove your ignition cylinder, you have a very easy straight shot at the top screw holding the pump on.
I used a 12" extension and a 1/4" socket through the hole for the ignition and it came right out!
Sturvin is offline   Reply With Quote
Old 02-12-2020, 04:49 PM   #23
Rogerlumibao
I read this after having issues with my pump and didn't want to do all the work (with AC) and didn't really care about rebuilding old one . So I also went to napa and bought their universal kit. Ran wires from ground to pump, power side of pump to to a push button under dash, the other side of switch to fuse under ignition on fuse box. Works great maybe too well and had to readjust the nozzles. Total money spend 40bucks with pump kit, extra wire, switch, bracket, and 7 feet of hose.
Rogerlumibao is offline   Reply With Quote
