10-16-2011, 07:00 PM | #1 |
It followed me home?
wtb stock leaf spring hangers
Im looking for some stock rear leaf spring hangers. Shipped to 80134, thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-16-2011, 07:20 PM | #2 |
Re: wtb stock leaf spring hangers
Which ones the rear or the front / rear spring hangers. Also 1/2, 3/4 or 1 ton also there are 2 different lengths of one tons
10-16-2011, 07:30 PM | #3 |
I need the frontand rear brackets for the rear leafs, 1/2 ton
10-20-2011, 09:42 PM | #4 |
Ttt
10-20-2011, 09:50 PM | #5 |
Chris
loal gm dealerships may still have them have you tried?
We had to buy one for the front of our 86's rear leaf and had to buy one for the back on our 84 c10. Both came from gm dealerships. If nothing else call em and they can give you other dealers numbers, you can call until you find one and have it shipped, or go online and check.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
10-20-2011, 10:02 PM | #6 | |
10-21-2011, 07:12 AM | #7 |
Don't buy the aftermarket hangers they are no were's near the quality of stock. Just wait till someone is parting a 1/2 ton out here. I am very surprised noone has a good complete set.
I think noone want to take out all those rivets. lol. |
10-21-2011, 07:36 AM | #8 |
Chris
LOl just wanted to let you know, most ppl are like me and think gm has nothing for old trucks anymore.
Don't hurt to try though, we found some. as for rivets they aint bad our big grinder took care of em quick, took longer to grind upper ball joint rivets then it did spring hanger ones.
10-26-2011, 11:10 AM | #9 |
ttt
10-26-2011, 04:39 PM | #10 |
i get ya a set for 100. 25 a bracket plus whatever shipping is
10-29-2011, 01:25 AM | #11 |
I'll look around and see what I have. Free If I find some...
Posted via Mobile Device |
11-03-2011, 12:36 PM | #12 |
Any luck? I found some fronts so I only need rears and frame supports
11-05-2011, 07:53 AM | #13 |
I have some, but they have grind X's where I ground and then air hammered them off. And if u want cheap then really they are not even worth someone boxing up and shipping.
And yes it was a pile of rivets. I have fronts and rears they are easy to get though, just go to a junk yard and get some. the 4x2 and 4x4 are different, they will bolt on, but the 4x4 are longer providing more lift. I got mine from a junk yard, they just cut the whole back of the frame off and gave it to me and let me have fun with the rivets. 1/2 and 3/4 will swap, the 3/4 are only thicker. |
11-05-2011, 08:33 AM | #14 |
1/2 and 3/4 are different. 3/4 are a couple inches taller or longer and the spring perch offset are different.
