10-17-2011, 10:02 AM | #1 |
"Tuff man bars" and anti-roll pics
I am looking for pics. of anti-roll setups and roll cage pics. for ideas. The old truck is headed to the chassis shop next and any advise would be greatly appreiated!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
10-17-2011, 09:52 PM | #2 |
Re: "Tuff man bars" and anti-roll pics
tons of pics in my build thread.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-17-2011, 10:43 PM | #3 |
Thanks Kevin! I have been burning your build thread up. That is a awesome truck! I didn't want to cut the bed up for a anti-roll or shock mount but it looks like I am going to have too to get the travel for the shocks. The classes around here are going to no larger than a 29 10.5 no W's and any size drag radial so I know I need to get some of the flex out of the truck a choose the correct tire. I keep telling myself well Kevin did it not thinking of all the lightening/chassis work you have done on your truck. I have no idea What this thing weighs in at now with all that has been changed. Before I just put it in the chassis man's hands I would like to get some input from some guys that have been there and done that! Thanks for all the help
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
10-31-2011, 08:51 PM | #4 |
post up a link, I`d love to see it.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
10-18-2011, 07:06 AM | #5 |
It could be done without hacking the bed floor if you don't go real low. I am using shorter qa1's on my son's truck and will keep a fake wood floor in tact. I saw a 64-66 model with the shocks mounted in front of the axle that didn't stick up too high. You could always just do a cover over the center section like the lowrider guys.
10-19-2011, 06:46 PM | #6 |
Does anyone have a anti-roll and coil-overs under a stock bed? My truck is lowered and I don't want to cut the bed up. Pics please
10-19-2011, 09:10 PM | #7 |
It's Better With Nitro
How narrow will your rearend housing and frame rails be?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-19-2011, 11:05 PM | #8 |
They are stock both stock
10-20-2011, 12:01 PM | #9 |
This is what I did with my stock width frame rails. I cut out the intermediate crossmember and welded in a tube to house a splined torsion bar (5/8") I had leftover from a customer project. I fabricated the aluminum arms and used end links with spherical rod ends.
Close up of arms... This allowed me to drop the rear very low without having to alter my bed, etc. You can use different thickness torsion bars...just use the corresponding housing tube diameter, etc.
10-22-2011, 05:03 AM | #10 |
Ive got coil overs and anti roll kit from autofab I believe,ill try and find or take a beter picture.
10-20-2011, 11:07 AM | #11 |
I am doing a coilover with a anti roll bar , depending on how low the truck will determine the bed floor. I am using a 19" Lamb[Koni] shock in front of the rearend housing. My floor will be cut. I will use a Rick Jones anti roll set up, and a wish bone to center the housing. I have longer shocks and will have the upper mounts higher in the truck. If I had to keep the bed floor in I think I could it I think, there is room between the frame and the bottom side of the bed. I have to cut the bed for tubs , and the roll bar connects to the frame in the rear anyway so I dont care about the floor. I dont have pics because I have to wait to get started on the chassis till December or January.
10-20-2011, 11:17 AM | #12 |
keep me in mind I plan on doing something similar and was looking for some help before I took on the challenge. Thinking now to just let a chassis man handle it.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 10-20-2011 at 11:22 AM. |
10-20-2011, 03:01 PM | #13 |
At the body shop.
Very cool. Id like to do that on my 73 just in back of the axle. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
10-20-2011, 05:59 PM | #14 |
I was trying to tie the anti-roll and shock mount in together because I don't have much space. I am not even sure that it can be done?
10-20-2011, 06:59 PM | #15 |
Thanks for the info. I am going to draw something up tonight and I'll post it up to see what you all think.
10-20-2011, 08:32 PM | #16 |
Man these sexy trailing arms are killin me. I don't know if I should buy some or build some. Vin 63's race car anti roll looks like mine from S&W.
10-22-2011, 12:11 AM | #17 |
I was wrong My parachute mount came from S&W. Here is where my anti roll came from.
http://www.appliedracing.com/anti-ro...ional-kit.html
10-31-2011, 09:43 PM | #18 |
01-25-2012, 11:45 PM | #19 |
Bigboybodry ,
I Have Strange coilovers and a Bickel antiroll under a stock bed floor. Here is a couple pics will get some better pics of coilovers and a pic of antiroll?
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30 Old Motor: 60'. 1.43 1/8 6.58@104.64 1/4. 10.42@127.10 Nitrous: 60'. 1.28 1/8. 6.15@ 112.02 1/4. 9.75@ 136.32 |
01-26-2012, 12:58 AM | #20 |
SWEET RIDE!! What is the travel on the shocks and what does it 60? is the anti roll and upper shock mounted in the frame rail?
