Old 10-17-2011, 09:17 PM   #1
Jarwood
Jarwood's Avatar
Installing Power Brakes
Members,
I am wanting to install power brakes to my 72 GMC. Can anyone lead me in the direction of where to buy the parts and how hard the install is.
Thanks,
James
Jarwood is offline   Reply With Quote
Old 10-18-2011, 01:10 AM   #2
AustinScott
AustinScott's Avatar
Re: Installing Power Brakes
performance online sells a kit.
I just bought all new stuff from them to swap out my old stock power drumbrake setup.
It should be here by the end of the week.
I can post up some info when it arrives if you would like.
I purchased the below items..
Booster & MC Kit
Front Power Brake Line Kit
Disc conversion kit
Scott
AustinScott is offline   Reply With Quote
Old 10-18-2011, 02:37 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
are you keeping the rears a drum setup or disc brakes too
i got mine from cpp
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 10-18-2011, 07:22 AM   #4
hugger6933
If you are gonna keep the current configuration[drum,drum] it would be a matter of pulling the m/c loose from the firewall. After that you would be ready for the booster install and then bolt the m/c back up to the booster.
There was a write up about two weeks ago on someone that went to a booster system and did'nt break the lines loose or anything like that so no bleeding was needed. It appears to me it is as simple as replacing the m/c because you just unbolt and place the booster in between. Then all that would be left is to plumb it by adding manifold vaccum
hugger6933 is offline   Reply With Quote
Old 10-18-2011, 08:08 AM   #5
bigsnookmaster
bigsnookmaster's Avatar
It would currently be a disc/drum being a 72. You need the booster and correct rod that goes into the booster, with the bracket for the booster. You also might need a different proportioning valve, but I'm not sure on that. Good luck
bigsnookmaster is offline   Reply With Quote
Old 10-18-2011, 11:18 AM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
You have the right MC and PROPORTIONING VALVE CURRENTLY.
Just get some brackets from the board/junkyard and a booster, if the booster is good then your lucky paint it up and run it, it its bad well you've saved yourself the $ for a core
John
1999 Toyota Tacoma 4x4
Old 10-18-2011, 11:57 AM   #7
hugger6933
Sorry, still half asleep when I posted, but he still should have all he needs exept the booster, line,and brackets
Old 10-18-2011, 02:40 PM   #8
68 IRON
68 IRON's Avatar
Originally Posted by Jarwood View Post
Members,
Thanks,
James
James, I was lookin' for this last week. Heres the link everyone is talkin' about.
http://67-72chevytrucks.com/vboard/s...d.php?t=221598
Looks pretty straight forward to me...I like easy!
Oh, and another thing.....Welcome to the board!
68 IRON is offline   Reply With Quote
Old 10-18-2011, 08:23 PM   #9
Jarwood
Jarwood's Avatar
Thanks,
It does have disc front and drum rear. So I can use my current master cylinder and by a booster. Then after install bleed everything correct?
Old 10-18-2011, 09:05 PM   #10
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Welcome to the site from Texas!
If you will take the master loose from the firewall, and dont take the brake lines loose you wont even have to bleed the lines. Just slip the booster in between and bolt it all together.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 10-18-2011, 09:26 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Just buy a 71-72 booster.
Look here in the classifieds to get the correct mounting bracket.
(You might even find a booster also)
Keith
Convert to disc brakes.
