10-18-2011, 11:06 PM | #1 |
Eat, Sleep, Drive a Chevy
Complete Power Brake Booster Assy
I have a good used power brake booster with master cylinder and prop valve for sale 80.00 plus shipping
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
10-19-2011, 12:41 AM | #2 |
Re: Complete Power Brake Booster Assy
What is this off of? I'm wondering if it will work on my '69 GMC 2500.
10-19-2011, 05:37 PM | #3 | |
The 3/4 ton units are a little larger, so it wont work for you, sorry
10-19-2011, 05:45 PM | #4 |
Is this prop setup drum/drum or drum/disc?
Thanks, |
10-19-2011, 05:47 PM | #5 |
It is a disc/drum
10-20-2011, 09:10 PM | #6 |
Sorry, having to pass on a few things. Forgot car tags this month.
Cheers, |
10-23-2011, 09:44 AM | #7 |
w/e bump
10-23-2011, 09:37 PM | #8 |
Pardon my ignorance but.... Is this everything I need to switch my 70 1/2 ton over to power brakes? I was told I needed the front lines. I have manual with discs already swaped up front and drum rears. How much for shipping to 72401? Thanx
10-24-2011, 08:33 AM | #9 | |
Since the brake lines on your truck go directly to the master cylinder they would need to be bent to be moved to connect to the prop valve on the power assy. I am not sure if there would need to be any other mods hope that helps shipping to you...20.00
11-11-2011, 10:02 PM | #10 |
ttt
11-12-2011, 09:04 AM | #11 |
GEARHEAD
In order to convert to power brakes the rod between the pedal and booster must also be swapped. They have different ends on them, but are not that hard to find at a junkyard.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-12-2011, 09:40 AM | #12 |
Quit if it's not FUN!!!
Still available??. shipping to 29708
11-12-2011, 09:54 AM | #13 |
I still have it. I will get you a price, just a quick guess I would say 20.00
To be quick and easy I will do 100 shipped to you, if it is a few dollars more then I will cover it.
11-14-2011, 06:13 PM | #14 |
if you still have the setup i am in the Houston/Huffman area...
11-15-2011, 12:27 AM | #15 |
At this point no one has said "I'll take it" so I still have it
11-15-2011, 10:11 PM | #16 |
Ill take it, pm me your paypal address
11-15-2011, 10:41 PM | #17 |
Sold to kamikazekyle...pm sent
