10-24-2011, 06:51 PM | #1 |
dare to be different engine choices?
hopefully i dont get shunned for this, but anyone on here used an engine other than chevy in their trucks, or know someone that has? my dad had a gto when i was growing up and i have a 350 or 400 pontiac lined up to go in the 64. anyone know of people dropping poncho power into an ol chev or gmc?
10-24-2011, 07:00 PM | #2 |
Re: dare to be different engine choices?
I bought a '60 short step for parts years ago that had a 350 pontiac in it. A nailhead would be cool.
10-24-2011, 07:12 PM | #3 |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
10-24-2011, 08:55 PM | #4 |
It's Better With Nitro
Yep, I run a 462 ci Pontiac in my C-10.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
10-25-2011, 12:12 AM | #5 |
10-25-2011, 09:01 AM | #6 |
Yes, sir...running KRE D-Ports on the truck, and the High-Ports on the Funny Car. Here's a link to my introduction thread when I tore the truck down again: http://67-72chevytrucks.com/vboard/s...d.php?t=288712
Here are a couple more photos of the engine, in case anyone else is interested in running a Pontiac... This is the dyno sheet on this interation of the engine on 91 octane:
10-24-2011, 07:38 PM | #7 |
nailheads are AWESOME! how did that truck go with the 350?
10-24-2011, 08:55 PM | #8 |
I put the laughter n slaughter
Nailheads FTW!!! I have pics of mine in the link above. Got it back from the machine shop thursday. Picking up another 401 naily saturday. Approx 60,000 miles on the engine, complete except intake and rockers. $100
I still dont care how you did it in California!!! |
10-26-2011, 11:37 PM | #9 |
10-24-2011, 09:36 PM | #10 |
1961 crewcab
put a 75 455 and a th350 out of a 79 ta in my 63 long step dropped right in!
used the shorter 3 speed on the column driveshaft,and also used a set of motor mount towers out of a 73-87 3/4 ton 2wd, -direct bolt up to both-. pirated the transmission crossmember out of the 79 ta, 2 bolt holes lined up, and had to drill 2. had to remove the e brake crossmember for clearance, and haven't figured out what I will do there yet... thinking of seeing if the 66 style e brake system will work. cut the original bellhousing mounts off the frame. had an exhaust shop bend some 1.5 inch tube for the upper radiator hose, and had to trim the stock aircleaner to fit around the deluxe heater... used a stock auto column out of a 63 gmc, might have been a hydromatic? regardless it had the correct detent for the th 350, used the linkage from the 73- 87 auto, including the bellcrank(?) and its mount that is bolted to the 73-87 frame. if I can I will get some pics of the install soon. used the stock pont. exhaust manifolds and cross over pipe for now, but dual exhaust doesn't seem like it would be a problem.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-25-2011, 08:55 AM | #11 |
nailhead for 100?! thats crazy! vin that motor is just beautiful! i bet that thing cranks, id love to see the rest of the truck. and jonz pics of tht install would be primo! this is great, im glad im not the only one that wants to do this
Posted via Mobile Device |
10-25-2011, 05:22 PM | #12 |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
10-25-2011, 09:26 PM | #13 |
I have a s10 2.2 4 cylinder in my 65. yeah I know it wont win any stoplight races but its pretty close to the stock hp and tq and I dont have little man syndrome anyway. just kidding. It drives just fine though, plenty of pep.
10-26-2011, 10:26 AM | #14 |
A buddy of mine is building a pretty radical Ecotec for his '57.
10-27-2011, 09:44 AM | #15 |
10-27-2011, 01:10 PM | #16 | |
Stock 98 s10 drivetrain, so I think a .7 overdrive and 3.73 rear. I haven't run a full tank through it yet, had it together with the 62 body and changed to a BBW 65 cab. But the sum is lighter than the s10 and the c10 so it should better the 25 predicted by the s10, depending on the aero effects. Posted via Mobile Device
10-27-2011, 08:30 PM | #17 |
That's interesting and I hope it meets your expectations .
10-27-2011, 10:15 AM | #18 |
no replacement for displacement , I'm looking to slowly stockpile parts and cash for a big block
10-27-2011, 10:21 AM | #19 |
Same here bo-w, generation 4 block....
10-28-2011, 09:25 AM | #20 |
I guess my next different swap will be a 250 with a turbo , i got the manifold yesterday and the turbo about 3 months ago ....
10-28-2011, 09:30 AM | #21 |
I always wanted to see a early Chrysler Hemi in one of these trucks
11-02-2011, 06:32 PM | #22 |
its funny you mention that! i just got a line on an old 392 xD haha that would be sweet! awbrown, where do you find info on stuff like that? i cant picture how the turbo would go on a 250...what kind of rpms would you be running with a turbo? must have to be a small-ish turbo to get full spool with the I6 rpm range? might have made myself sound stupid but im curious!
11-02-2011, 07:09 PM | #23 |
I did the opposite, I install a chevy engine
into this now I want to install Chevy Vortec engines on anything |
11-02-2011, 07:41 PM | #24 |
6>8 Plugless........
Very cool!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-02-2011, 09:01 PM | #25 |
I like the 4 cyl s10 idea....
Build Thread - Papa's truck build up |
