Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 10-27-2011, 12:54 PM   #1
puller
1970 3/4 step side puller build (blue blood)
Hear is my 1970 chevy C20 I am building to drive and do some truck pulling. I bought the truck on ebay years back from state of michigan. The truck spent its life on a island in lake michigan called beaver island. I am not sure what truck did but it had fire fighting equipment and large radio with amp under seat with 6 foot wipe antenna mounted to back of cab. The truck is rust free but had dents in every panel. It showed 45k on speedo and I believe it could be orignal milage. Factory drive train was a 307 with sm465 4 speed with 205 t case and 4.56 gears in dana 44 front and rockwell rear. I do have orignal bill of sale to state of michigan. I am trying to dig up orignal pictures. will post them when I find more
puller is offline   Reply With Quote
Old 10-27-2011, 03:29 PM   #2
jason65
Registerd User
jason65's Avatar
Re: 1970 3/4 step side puller build (blue blood)
Looks like a nice project. Those must be some sticky tires.
jason65 is offline   Reply With Quote
Old 10-27-2011, 03:40 PM   #3
puller
Hear are some pictures of 2007 when I set truck up for stock class truck pulling. I bought used 454ho crate motor installed with centerforce dual friction clutch, changed rear end to 14 bolt with detroit locker, added 10 leafs springs to rear and new 3 leaf front springs, new 35 bkgs and went pulling. Had alot of fun placed in top 5 all pulls and first once that summer. But I broke 44 front and lost main bearings in 454. pictures are pulling 307, new 454 installed
Old 10-27-2011, 03:57 PM   #4
puller
After loosing main bearings in 2007 I rebuilt 454 with 10 to 1 forged pistons, zz502 hydralic roller cam, dynoed with restictive cast exhaust manifolds (have to run all cast in stock class and pull 14 inchs vac) made 450hp at 5600rpm and 550tq. I drove truck alot and only hooked once and I was again loosing oil pressure. Pulled motor apart and had block sonic tested and found cracks in block near main oil vains. I then decided to put truck in barn and save some money to restore. That brings me to this summer 2011. picture of frame mods traction bar, ajustable bump stops, hitch, steering box brace, sway bar, motor mounts.
Old 10-27-2011, 04:08 PM   #5
puller
More pictures drive shaft loops, traction bar, motor mounts moved ahead 2.5 inchs and down about an inch for more room by fire wall. also added crossmember to support new bump stops and added hitch brace to pull more from front of truck. My goal is to keep truck looking as stock as possible and still compete in open stock pulling class. That is y I mounted traction bar inside frame rails.
Old 10-27-2011, 04:16 PM   #6
puller
also should note I swaped dana 60 in front out of 1 ton daully. Had to change hubs to single wheel set up. Also bilt some stainless bumper stops that are removable to protect back of truck if pulling sled rear ends truck.
Old 10-27-2011, 04:19 PM   #7
puller
sand basted pictures. Getting ready to paint with POR 15 satin black.
Old 10-27-2011, 04:25 PM   #8
puller
Painting frame. Turned out nice. Would use POR 15 again. Single stage no primer and sticks really good.
Old 10-27-2011, 04:34 PM   #9
puller
Rebuilt trans sm465 and 205 T-case. Prepping for paint.
Old 10-27-2011, 04:38 PM   #10
puller
painted and installed in new poly mounts.
Old 10-27-2011, 05:05 PM   #11
onebadbowtie
onebadbowtie's Avatar
sweet looking project so far!
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 10-27-2011, 10:09 PM   #12
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Looks like your building a serious pulling machine..I've always thought a longstep would make a Tuff Lookin puller! keep the progress pics coming
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-28-2011, 12:50 AM   #13
jbclassix
Junk Yartist
jbclassix's Avatar
following along!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 10-28-2011, 08:12 AM   #14
jason65
Registerd User
jason65's Avatar
Good looking chassis.
Old 10-28-2011, 10:19 AM   #15
puller
Thanks guys! Having alot of fun with project. Here is pictures of 3 inch stainless exhaust I fabbed. Had to exit just before my cross member for traction bar. No room beyond that. Cant wait to hear some music thrue them 2 chamber flowmasters!
Old 10-28-2011, 10:24 AM   #16
puller
Painting rancho shocks, bought blue boots to match "blue blood" project.
Old 10-28-2011, 10:30 AM   #17
puller
Getting doors ready to bring to media blaster. Also glove box truck specs.
Old 11-25-2011, 10:23 PM   #18
cheyenne402
Interested in selling that red glovebox door?
cheyenne402 is offline   Reply With Quote
Old 11-27-2011, 01:56 PM   #19
Iron Hauler
Iron Hauler's Avatar
That Baby is built for Bear!! will this truck be street driven as well?
Iron Hauler is offline   Reply With Quote
Old 10-28-2011, 10:38 AM   #20
puller
Look what I scored on craigs list! Factory 16.5 x 9.75 wheels for 125 dollars! Should make hear look like a sleeper at the track. I like the stock steal wheel look especially with wide stance!
Old 11-21-2011, 12:31 PM   #21
puller
Cab is now bolted down with 3 inch body lift, also blasted and painted my 16.5x9.75 wheels and mounted some 31/12.50 bfgs on them. Have to put project on hold for little it is time for my kids snowmobile ice oval racing soon here in WI and I am crew Cheif and head wrench for my 7 year old daughter and 9 year old son.
Old 11-22-2011, 12:27 AM   #22
jbclassix
Junk Yartist
jbclassix's Avatar
L-O-O-K-I-N GOOD!!!!! That's exactly how I want to run my steelies on my burb!!
-Jeremy
Rebuilding an NP205
Old 11-22-2011, 09:52 AM   #23
Curt's_72
Curt's_72's Avatar
What a great look. I'm running a 31x10.50 BFG on 8.25 steelies. I was lucky enough to find the same deal as you on a set of 16.5x9.75's. I'm thinking of running a 33x12.50 BFG on those, but I've never seen a 31x12.50. Are yours 33's?
Curt's_72 is offline   Reply With Quote
Old 11-22-2011, 10:11 AM   #24
puller
Thanks! Yes 33/12.50/16.5 all terrains. My plan is to paint roof white to complement wheels. Hear is a closer look at tires
Old 11-22-2011, 10:16 AM   #25
Curt's_72
Curt's_72's Avatar
Dude, That wheel looks awsome. The chrome lug nuts are great. Doyou know what the back space is? I've got three sets of these, and none are the same. I'm concerned that mine will stick out too far. Yours appear to sit just right on the front hub.
