69 swb exhaust question
how do you get flowmasters or another exhaust system to fit? do you bend the pipes?
also which sounds better flowmasters or magnaflow? |
Re: 69 swb exhaust question
ya your going to have to get some pipe bent up
#3 | ||
Quit if it's not FUN!!!
First off, welcome aboard. . ![]() ![]() I'm guessing, from your questions, you are kinda' new at this stuff. Take heart, we all gotta' learn somehow. . Best advice, take it to a local muffler shop and tell them what you want. If you can, get a couple of quotes and then move ahead. I know that requires a little $$ up-front, but you'll be way ahead and you'll have a system that last. . Keep the faith and stay after it. . Quote:
. Magnaflow are generally a little more mellow. . Go to a local cruise-in and listen and ask questions. You have to decide which sound you prefer. |
![]() Join Date: Aug 2003
Welcome to the Board Just Samples.
Couple of questions: Is this your Daily Driver? What engine are you running now? And are you going to add any "Go Fast" goodies to the truck? Like a Hotter Cam and Headers? I own a SWB and I had a custom shop do my system. I think it was the best value for my money. It fits my truck and doesn't rattle. Plus they can do a better job of fitting it to your truck and if they're worth a damn, they'll stand by their work a year or more down the road. I'm using Hooker 2-1/2" Aerochamber mufflers with my system and they sound a Hell of a lot better than flows or Magna's, but that's just my opinion. Summit has Aerochambers for 70 bucks-a-piece. I chose the SS version and did all my pipe in SS, cause I don't feel like spending anymore money on my Exhaust system. I got it all in SS and welded and it's done deal for the next ten years (or More).
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
I am running a ZZ4 350 from GM and a B&M Racing transmission. he said it already had flowmasters but they are no where near as loud as others.
Do they fabricate the pipes there or do i need to buy the complete system off line and take it too, i was going to run from end of headers back. Yea i am brand 'new' to this ![]() |
New - No Problem
. Flowmasters come in several styles, each with a different noise level. But, they all sound like Flowmasters to me. . Check their website for samples. I think some other sites may sample too! Try DynoMax (Walker) and Magnaflow. . Find out what you like.
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) ![]() |
I've had Flowmaster on pretty much every car I have ever owned, so I can be a little bias. My last truck was a 97 Sierra with a 350 Vortec in it, with custom true duals 2.5" Flowmaster's and loved the sound a lot of people liked it. It could get loud though. But it was deep and wasn't too loud when just driving around but that wasn't with headers and cammed motor.
#8 | |
Like Toby said it's YOUR decision, but if you're looking for LOUD, then go with Flowmasters. If you're looking for more low-end rumble and getting a Deeper tone then my recommendation is for the Hooker Aerochambers or the Magnaflows. Do a search on Youtube and listen to a S-load of videos. I have a 350/350 Combo with 2-1/2" Stainless and the Aerochambers. I get a really nice low-end rumble and not any "RAP" sound from it at all when I step on it. Sounds awesome from standing still through 70mph. The shop did all the bending of the piping and hanging. If you want, you could buy your own pipe, but I'd just let them take care of it. Make sure it's a Reputable shop.
#9 | |
. I took some pictures with my phone, posted below. As I said, I paid $ to have someone to fab my exhaust. I'm 65 and still very capable of doing it myself, but I've finally realized that paying someone who has the right tools, saves me much time and much more frustration. Nothin' fancy, just two Thrush Turbo ($25/ea.). Moving mufflers to the rear really did move the noise source further back. And like the shop guy said, with 'em at the back, chopping 'em off and changing to something else becomes a non-issue. So............ . Pic #3 shows the full run up to the OEM manifolds. Took off 4-tube headers (God, I must be gettin' old).
#10 | |
Active Member
![]() Join Date: Jul 2007
Not a bad idea. Definitely would make for ease of replacement and or swapping. |
![]() Join Date: Feb 2004
Most of the mufflers mentioned have a crackle when romped on my preferance is dynomax super turbos mellow at idle but deep agressive growl when romped. If you want to spend very little just cut it off before the axle and put two turn downs pointed straight at the ground. Even if you go all the way back dumps will always be louder. Id say get on youtube and search and listen to different brands on many set ups use earbuds to get a good feel of the tone.and one final thought camshafts play a big role in the tone and loudness of a exhaust through the entire rpm band so dont be suprised when you buy what someone else is running and dont get as agressive sound as them.larger pipe will be louder but there is no need for to go bigger than 2.5 it will kill your low speed tq. Good luck and welcome!!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
does the pipes matter, i know the size does, but the pipes dont make a big difference in sound does it. the muffler is what chages it mostly.
The ones currently have been welded on so i would have to cut or take off from headers back... |
#13 | |
. Don't know if S.S. would make a difference, I can't afford S.S. I figure what I've got will have to last more than a few years.
Size does matter in the sound department, the smaller the pipe the louder and more raspier and popping it's going to be. I would say 2.5" would be a safe bet. I have done that on a lot of cars and trucks and always just sounds better
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS 1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI 2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS |
#15 |
I am a Referee of life.
The real difference in "Pipe" is the bends and length.The bends need to be mandrel bent so that they don't bunch up or collapse in the bends.Length will also affect the sound some shorter is usually louder.Side exit also always seems louder to me but unbalanced since I can hear one side better.
Do some research and decide what "YOU" like before you spend the $$$.Exhuast last a long time if done right.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#16 |
laying low
![]() Join Date: Mar 2001
Nothing wrong with putting the muffs at the rear. Vettes and Camaro, Firebird, Nova all have had them back there. It's actually a pretty good idea. I have wondered if a crossflow muff from an early Camaro might mount up and sound good on a truck.
#17 |
laying low
#18 |
How about some good ole' Cherry Bomb glass packs?
They're probably too loud for you. I like my flowmasters on my 383. |
#19 |
![]() Join Date: Jun 2006
I run Flowmaster original 40 series on all my restorations
#20 |
here is how i done mine. its 3" I had to make pipe to connect headers to kit because the f body headers kick out towards the frame, but other than that i just used a jeggs x pipe kit and super turbos. a regular sbc would be easier caus most headers come out straight. I would have loved to go through the custom member like its intended but becuase of the engine set back and 80e just did not have room for x pipe
#21 |
so i just buy the muffler and get a muffler shop to fabricate my pipes right?
#22 |
The shop we go to will test fit different mufflers so you can hear how they sound on your truck or car. The guys I talked to recommend 2 1/4 pipe with magnaflow mufflers since I don't want to irritate the neighbors too much
1969 GMC Custom Camper 1995 GMC Jimmy 4wd 2k Suzuki LC1500 |
#23 |
do some muffles like flowmaster outlaws not have a big rectangle box like super 44's?
What about the cat? i guess most older cars dont have em? |
#24 |
is Pypes exhaust any good?
Tags |
1969, c10, flowmaster, magnaflow |
