Which Way To Go??
1957 3100 with a 283. Truck will not be used to haul or tow. Just want a reliable cruiser that can ride thru town or jump on the highway without worry.
Current set up is a TH350 with original 57 rear and 3.90 gears. 40-50 MPH = about 2500 RPM so I usually just stay off the interstate and even in town, my gas mileage is suffering. My question is should I go with a different (6 lug) rear end or keep it and swap out the TH350 for a 700R4. Would like to hear all opinions and advice. Thanks in advance.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Which Way To Go??
If your looking for better mileage I think the transmission swap would accomplish it better than a rear gear swap.
IMHO if you do the gears only your going to see a drop in driveability around town. The best case would be to do both. Just as a reference my brothers 62 f**d with a modular V8 has a 4 speed auto with 3.25 gears and gets 20 mpg and is real easy to drive around town and on the highway. Kim |
Change the transmission. 4th gear is .70 so your 2500 rpm will drop to about 1750. Also has a lower 1st gear for quicker off the line response.
The trans change would probably give you the best all around driving truck. It would have decent highway manners but still be able to pull a trailer or have good low end acceleration.
I went with a early Camaro 10 bolt 273 gears, with a turbo 350 I run 70 on freeway all day long. Easy to find, 2" narrower than stock so you can run a deeper rear wheel. Will need to install new spring perches but you will need to change things to run 700R4, more cost effective I think to do rearend. Oh yea it gets alot better mileage too, my driveability is great around town, will do a first gear burnout.
Truck's just for the fun of it. ![]() |
#6 | |
![]() ![]() Join Date: Nov 2008
Pretty sure this is my gear ratio too. I have a (too) cammed 283 with Edelbrock dual plane intake and Holley carb, headers. 10 bolt rearend and I can freeway drive with no issues at all. Older Chevy 5 x 4-3/4", 5 lug pattern.
You can also purchase a 3:38 to 1 ring gear and pinion for your stock rearend.
http://www.yukongear.com/ProductDetails.aspx?ProdID=823
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
