11-09-2011, 06:07 AM | #1 |
What have you found that works?
My 72 I just got has a fastburn with the aluminum d port heads on it. The previous owner had begun installing and bolted up longtube headman headers. The thing is I plan to lower the truck with the 4-6 ECE or like type set-up. I was wondering what header would work and not be so low to the ground. Heck the header hang down really low already and it's not dropped yet.
My father uses the block huggers on his older street rods but I think they would get into the crossmember.... Any suggestions on what works would be great. I searched and found some stuff but most of those post are older. Any ideas? |
11-09-2011, 06:28 PM | #2 |
Re: What have you found that works?
I have one suggestion for Sanderson anyone else? Is anyone running the fastburn or at least that style heads? I hope it's a good engine...
11-09-2011, 09:11 PM | #3 |
Something to check out would be headers made for a Chevelle.I have not tried them but a friend told me that they don't hang down as low as the ones made for a truck.
11-10-2011, 05:43 AM | #4 |
These are the two I was looking at... Anyone using this style header? Both are for d port angle plug heads. One set from Speedway and the black ones are Sanderson.
11-12-2011, 03:10 PM | #5 |
I run sandersons on my 65 nova coupe zz4,hot cam, 1.6 rockers. and they are great! I also run Camaro headers on my 71 avatar truck 3/4 length and they work &fit well. cheers, Pat
11-10-2011, 07:06 AM | #6 |
The center dumps won't work due to the crossmember location. The Sandersons people suggest and the Chevelle-type are both 3/4 length. They will only work with automatic. I see people having full length headers that hang below the frame. I've never had them hang below the frame and don't have problems with 4/6 lowered truck ground clearance. The Headman Elites on my '72 K2500 sit up in the frame.
11-11-2011, 07:18 PM | #7 | |
Thanks for your input |
11-12-2011, 12:53 PM | #8 |
these will not hang past frame i can assure you i have the big block ones and you cant see any part of my exhaust except tips which is the way i wanted. they was running a special on the price awhile back you would be really happy with a set of these.
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
1971 rs camaro under the knife ls3 6 speed swap 1970 396 big block shorty fleet 67 clone 2010 rs/ss camaro |
11-12-2011, 02:28 PM | #9 |
its all about the +6 inches
I had hooker comps on a 69 short/fleet, had about 3 inch sag/drop in front. The headers hung down a tick, but probably noore than an onch or two. The front crossmember would smack the pavement before the headers (and it did hit a few times).
Posted via Mobile Device |
Tags |
fastburn 385 headers |
