Old 11-10-2011, 07:43 PM   #1
primetime
primetime's Avatar
67 frame questions
after a lifetime of searching (it feels) i finally found a swb frame. its local. i'm thinking i'm getting a great deal on it too. sorry no pictures til the weekend. it has no engine,trans,doors, or interior but the frame and bed sides are great. i have some questions though...
1) is there a problem with a 72 cab on a 67 frame?
because i plan to use my good parts from my 72 lwb (5lug, disc brakes, brake booster, ect...)
the truck has a step side bed in decent shape,
2) how is my 72 cab going to look with 67 step side bed?
i cant wait to saturday comes to get started on this.
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 11-10-2011, 09:37 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: 67 frame questions
The cab will have side marker lights and the bed won't.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-10-2011, 10:28 PM   #3
PHAT TONY
PHAT TONY's Avatar
No parts problems I know of, step beds have no marker lights nor do cabs.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 11-11-2011, 01:19 AM   #4
Shyguy
Junior Member
Shyguy's Avatar
It will work. I have a '67 front clip and cab on a '69 swb frame with '71 running gear and a '68 short step bed. It will have a '74 454 with a '71 SM-465 tranny.
That is what cool about the the 67-72 trucks things are interchangeable.
The '67 frame does not have a dimple for power steering, but the steering box can be shimmed.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-11-2011, 03:28 AM   #5
sameyrasmea72
sameyrasmea72's Avatar
1. A 72 cab will mount to a 67 frame the exact way it would mount to a 72 frame, there is no difference there. The brackets were the core support mounts to the frame are a little different (a 67 frame has smaller holes), but that should not be a problem.
2. A 72 cab will be fine with a 67 bed. If you want the 67 step bed fenders to match the 72 front fenders you have a couple options:
a. shave the side markers off of the 72 front fenders.
b. sell the rear fenders off of the 67 bed that have no side markers and replace with 72 style fenders that do have side markers.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-11-2011, 12:46 PM   #6
MAK191
i did a similar swap and the routing for the brake lines is different but not hard to adapt/change.
MAK191 is offline   Reply With Quote
Old 11-11-2011, 01:03 PM   #7
stomper
Junior Member
stomper's Avatar
I am in the process of swapping a '67 SWB frame under a '71 long box truck. Here's what I have come across:
There is no dimple in the frame rail for the later year power steering box. I heated my '67 frame up and smashed it with a hammer. Now it's dimpled.
The holes are smaller for the core support bushings like said above. The Poly bushing kit I bought from Summit fit the holes perfectly but I haven't got the front clip on yet to see if it works right.
The brake and fuel lines routing is different. I believe the '71 has the evaporation line and a fuel return line. The '71 also had saddle tanks so it's somewhat of a mess but I'm sure I can make it work easily.
Looks like the brake lines from the proportioning valve down went on the outside of the frame on a '67 but inside on the '71. Not a big deal to make it work either way.
My '67 frame had some brackets to support the engine/trans at the bell housing. I read this was a '67 standard trans only thing.
Also, I think there may be some trimming on the upper inside edges of the frames on either side of the motor area after '67 to make room for the 400 but I'm not certain about that.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 11-11-2011, 01:10 PM   #8
michael bustamante
michael bustamante's Avatar
Brake lines are different on the front end and you have to use an adaptor for the rear end at the prop valve but thats no big deal at all. youll also notice youll have to bump a dent in the left frame horn area to accept the p steering gear better. other than that I dont think theres any real difference. I used 72 front and rearend for 5 lug disc brakes on my 67 and it was no real challenge
1967custom
michael bustamante is offline   Reply With Quote
Old 11-11-2011, 06:18 PM   #9
primetime
primetime's Avatar
tomorrow's the day. thanks for all the info guys. it made the difference in deciding to get this now, and picking up a '01 later. as opposed to getting that 01 now and prolonging this swb project.
