11-11-2011, 06:37 PM | #1 |
Cruise Control: TroubleShooting
I search this forum and didn't see much. I've recently picked up a 87' c10 that has cruise.
It doesn't work. I found one thread that said to inspect the wires coming from the cruise lever/switch on the steering column. It appears to be okay. All to say, after looking at my fuse box, I can't seem to identify what fuse maybe the cruise is running off of. Note: The Cruise lever on the steering column: The turn signals work, Only High & Medium speed setting for wypers work, the low/intermediate speed doesnt work. Maybe it's still the lever wiring, even though I don't see fray wires? Any suggestions..
87' R10 |
11-12-2011, 07:34 AM | #2 |
Re: Cruise Control: TroubleShooting
If no one has been messing around with the system before I would chek the wires comming from the lever again, and the contacts up in the head of the lever. I had problems with the cruise in a couple of corvettes. And it turned out to be the lever both times, I heard that this is quite common on GM´s.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
11-12-2011, 07:48 AM | #3 | |
Thanks Posted via Mobile Device
87' R10 |
11-12-2011, 09:05 AM | #4 |
Also, (and this is just my opinion, I could be wrong) check all vacuum lines . I removed some of the vacuum line under the hood , that I had no Idea what they were for and now my Cruise con. doesn't work either. Could be worth looking at in your case also
11-12-2011, 11:51 PM | #5 | |
87' R10 |
11-13-2011, 11:58 PM | #6 |
On my old 87, the cruise never worked until i got fed up and took some stuff apart. I took the big vacuum can on the engine, the one that actually pulls the throttle, found nothing wrong, cleaned it and reassembled it and then it worked like new from then on.
11-14-2011, 12:22 AM | #7 |
To The Levy
wiring diagram is essential, and a common understanding of its workings, dont forget the basics, like, brake swith, if its out of adjustment ( SOME use seperate cruise/brake light sw.) cable on throttle, vac. lines, like some already mentioned, get out your trusty test light or dvom and start checking for continuity when operating switch on and off, wiring diagram is helpful but not necessary if you know which connector under dash, usually a goofy looking terminal thin wires into a connector directly under knee bolster. also you power circuitry to make sure you have power and ground, but your simple basics should be inspected first, like brake sw. adjustment, cable, connectors, good luck
11-14-2011, 04:36 PM | #8 |
Edit Buttons Disappeared, so I need to add (I took it APART) and completely.
11-16-2011, 12:56 PM | #9 |
Home Built '87
How did you take the lever off? I had the same problem and am trying to replace the lever....I heard there is a connection to check as well between the level and the harness in the column??
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
11-16-2011, 01:13 PM | #10 |
Home Built '87
Please disregard my other post, I found this thread to help a bit on the removal!
http://67-72chevytrucks.com/vboard/s...teering+column
11-16-2011, 01:25 PM | #11 |
Excellent thread, and very timely.
When I first got my '87 back from my father in law the cruise did not work. That ended up being the wiring in the turn signal stalk (broken wires right at the base, near where it goes into the column. Replacing the lever fixed it and all was well. Now, after a couple years, it's stopped working again. I haven't dug into it yet, but am subscribing to this thread so I can follow along, and also in case I find something new. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-16-2011, 02:28 PM | #12 | |
87' R10 |
11-19-2011, 11:09 PM | #13 |
Lever did It! Done.
Thanks for the help to all. Posted via Mobile Device
87' R10 |
11-20-2011, 01:11 PM | #14 |
Anybody know where I can get a lever for my 83? It seems to be a 1 year only impossible to get part.
11-20-2011, 09:15 PM | #15 |
Any idea what's unique for '83?
I'm guessing there is some feature (like windshield wipers moved to the stalk) that maybe you could work around. K
11-21-2011, 04:53 AM | #16 |
misshape grape
Mine is inoperable in my 83. But I have a newer column. I will have to try the switch in mine
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did.. |
11-21-2011, 01:54 PM | #17 |
83 wiper switch is on the dash, the blinker stalk is just cruise - so I think that is the difference. Later models have combo wiper and cruise.
11-21-2011, 03:32 PM | #18 | |
Just thinkin' out loud - Edit: BUT - maybe then the electrical functions/connectors would not match. I dunno. K
11-21-2011, 04:16 PM | #19 |
misshape grape
I have wiper switch on the dash and the stalk. When I got it, the wipers worked off the dash. I think it was relatively easy making them work off the stalk.
11-21-2011, 05:26 PM | #20 |
78K & 79C Jimmys
I've been looking for info as it relates to everything else
i'm about to do this to,get the wipers,dimmer 88 or 89 to 78 i havn't found a "sure thing" but I got side tracked getting a tach cluster lol but those seemed were braking all the time,the cruise there in some later ones my plan was to remove it all from the the 89 wires n all figure it out that way,
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
