Old 11-14-2011, 04:47 PM   #1
profe56
Carb shock vacum
Can I conect Shock to EGR valve
Uploaded with ImageShack.us
profe56 is offline   Reply With Quote
Old 11-14-2011, 05:54 PM   #2
yuccales
yuccales's Avatar
Re: Carb shock vacum
I don't think so. The choke on your Q-Jet needs hot air from a tube that used to go where your egr valve is now. Others will help you out soon.
yuccales is offline   Reply With Quote
Old 11-14-2011, 07:38 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Neither will work. Choke needs heat and egr uses carb/ported engine vacuum.
68gmsee is offline   Reply With Quote
Old 11-14-2011, 07:37 PM   #4
profe56
