11-14-2011, 08:34 PM | #1 |
Radio delete plate
Can someone please post a pic of the correct radio delete plate for a '62 GMC . I've found the ribbed ones and the flat plate ones, and want to buy the right one for my year. Thanks
11-14-2011, 09:22 PM | #2 |
Re: Radio delete plate
one on ebay
11-14-2011, 09:27 PM | #3 |
So it is the ribbed plate?
11-14-2011, 10:06 PM | #4 |
I am no expert so I can't say 100% but if you search GOOGLE images this is the plate that returns under those search terms.
11-14-2011, 10:16 PM | #5 |
Senior Enthusiast
I can confirm the ribbed one is correct for 1960. Don't know when or if they were changed in the GMC models.
11-14-2011, 10:22 PM | #6 |
sounds good. Thanks for the info guys.
11-15-2011, 12:02 AM | #7 |
UCA63
My '61 GMC has the ribbed plate
T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
11-15-2011, 12:35 AM | #8 |
and the 61 chevy i picked up has a ribbed plate
11-15-2011, 12:54 AM | #9 |
look at the glove boxes in the photos. ribs match the ribbed 60-63 gb door, flat more or less matches the 64-66 style.
11-15-2011, 01:12 AM | #10 |
So I think with the 62gmc dash, the flat one would go better. There's nothing ribbed on the dash.
11-15-2011, 12:33 PM | #11 |
1961 crewcab
gmc changed dashes in 64 like chev. the only thing really changed on the gmc was the radio (larger than the 60-63) and the heater control.
so in order to cover the hole the radio delete plate breakdown will be the same as chev. ribbed 60-63 flat 64-66.... however I don't see why you couldn't use a 6456 on your 62...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-15-2011, 12:44 PM | #12 |
Thanks for the information guys very helpful. Decisions decisions...
