Old 11-14-2011, 10:19 PM   #1
kcsa75
kcsa75's Avatar
Intermittent loss of power
I was driving home tonight and the motor and radio would intermittently shut down for just a moment then start right back up. It was like someone pulled the plug on an electric motor then plugged it right back in. I know the motor and radio shut down, but the headlights, dashlights never blinked.
Any ideas?
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-15-2011, 12:04 AM   #2
trkfrk
trkfrk's Avatar
Re: Intermittent loss of power
I would start with checking for loose cables from the battery to the starter solenoid. It sounds like you have a loose wire on the ignition circuit. good luck.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 11-15-2011, 01:20 AM   #3
SS Tim
SS Tim's Avatar
Well, you are refering to two seperate circuts. The headlamps and dash lamps are on the battery circut (always hot). The engine and radio are on "run" and "accy" circuts. Both of these are switched by the ignition switch. I'd start there and see what everything looks like, the work down from there. Take a look at the schematic if you have one.
SS Tim is offline   Reply With Quote
