Old 11-16-2011, 02:09 PM   #1
theastronaut
theastronaut's Avatar
Retrospective 1978 Camaro Targa Top Project
A few years ago we had a guy come by our shop wanting a lift-off roof section for his '78 Camaro. Years ago he had cut a section out and had a canvas cover for it but decided that he wanted a metal insert. He had another shop put a roof skin on it but they did a horrible job and we had to redo that. It already had subframe connectors and a main hoop with front and rear down bars to stiffen the body. Our job was to make a one peice removable roof section, much like T-tops, out of steel. Once I got into the job I found that it had been hit and the quarter panel replaced and we had to rework some of the B pillar areas.
Here's a picture of a factory Porsche Targa top to give you an idea of what we were doing.
And here's what we started with. A very poorly done roof clip installation. Not only was it welded incorrectly, the alignment was way off and the glass would have never fit in the pinchweld. They didn't even get all of the lead out of the seam before they started welding!!
To fix that mess, I completly cut away the whole factory leaded/offset seam and made an new panel. I also replicated the factory inner brace, seen where the plug welds are.
The front windshield opening was misaligned so we cut it to repostion it. The rear cut was where the owner originaly wanted the opening to begin. We later talked him into letting the opening start farther forward, much like a convertible windshield frame.
The windshield frame blasted, primed, and repositioned.
The rear opening trimmed.
Trimming the front edge to the final opening size. The owner wanted the thicker windshield frame to start with but we realized that the corners would make getting in and out of the car alot harder without hitting his head. It also looks much better with the thinner windshield frame; like a factory convertable may have looked.
I'll work on posting some more pics later on. When we first got the car in the shop we really thought this would be a hack job and a something that would really kill the look and value of the car. We were wrong and it turned out to be a really neat project that looked like the factory could have made it. And with the top on, most people would never even notice that it had a lift off top.
theastronaut is offline   Reply With Quote
Old 11-17-2011, 01:53 PM   #2
NONHOG
NONHOG's Avatar
Re: Retrospective 1978 Camaro Targa Top Project
Originally Posted by theastronaut View Post
When we first got the car in the shop we really thought this would be a hack job it turned out to be a really neat project that looked like the factory could have made it.
I was thinking "oh boy" when I first started reading this thread, by the time more pictures came along. I like it! Never would have guessed.
Anxiously awaiting more pics!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 11-17-2011, 04:09 PM   #3
theastronaut
You and me both! We needed a filler job at the shop and the owner was willing to pay what it was worth so we jumped on it. Not the normal job we do but needed work at the time. Glad we did it now!
Here's some more pics of it.
W/S frame fully trimmed and ready to start boxing it. Used 18g bent 90* and shaped with a shrinker/stretcher from Eastwood. I left some of the inner brace metal on the bottom side of the w/s frame for the filler panels to weld to.
Drilled some holes to plug weld the filler panels to the existing inner brace panel.
Test fitting the filler panels.
Welding the filler panels in place.
Welds ground down and sanded with a DA. The lip will be used to hold a rubber seal for the roof.
Edges trimmed.
Old 11-17-2011, 04:26 PM   #4
theastronaut
The rear filler panels were a little bit simpler to build. I did have to notch them to clear the rear down tubes. Made a template of the shape of the roof and used the shrinker/stretcher again to shape them.
Section cut out to clear the down tubes, then used the S/S to make contoured notches.
Welding the rear filler panels in.
Both sides done and the welds ground down and smoothed.
Test fitting the rubber seal.
This was the original plan for the front and rear roof braces. Planned on making a hat channel and using the edge of the roof skin to create a hemmed edge to hold the hat channel in place. This would strengthen the roof panel and create an edge for the rubber to seal on. We later found some 16g rectangle tubing to make the braces with that turned out much better.
Old 11-17-2011, 04:59 PM   #5
Pop's C-10
Pop's C-10's Avatar
nice metal fab
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-17-2011, 05:25 PM   #6
theastronaut
Originally Posted by Pop's C-10 View Post
nice metal fab
Thanks Pops!
Old 11-18-2011, 02:27 PM   #7
theastronaut
Instead of using the hat channel for the roof skin braces, I was able to find 18g 1.5"x.5" rectangle tubing for the front and 1.5"x5/8" tubing for the rear. The rear filler panels I made had a deeper recess than the front, so the roof skin brace needed to be taller for a proper fit against the rubber seal. I built a tubing roller to shape the tubing to the shape of the roof skin.
I built a tubing roller to shape the tubing.
Tubing shaped with the roller. It's curved both ways to match the shape of the windshield frame.
Bending the rear brace.
Once it was bent I cut the sides off of the ends and shaped the tighter part of the curve by hand, then welded new sides into the tubing. The roller wheels were spaces to far apart to make that tight of a bend.
I welded a strip across the rear edge of the roof panel to strengthen it, much like a hemmed edge would be.
Welds ground down and smoothed. Once I was able to mount the roof panel, I welded 1/8" welding rods to the edge to fine to the panel gaps front and rear.
Old 11-18-2011, 02:32 PM   #8
theastronaut
At this point the front of the roof panel was too short since the owner originally wanted a smaller opening. I had to fab panels to lenthen the roof before I could add the front brace. I rolled a hemmed edge with a friends bead roller on the front and sides of the panels. I messed up the sides when I rolled them so I had to cut them off and weld new peices on later.
Fully welded and ground down.
I tack welded the rear brace in place to check the placement. Once it was in the right spot, I drilled the roof skin and plug welded the skin to the brace all the way across. The spot welds were ground down and the seam was filled with SEM epoxy seam sealer.
Also had to make reliefs to clear the humps in the filler panels for the down tubes. With the rubber seal in place, the humps wouldn't allow the roof panel to seat all the way down. I cut the brace and filled in the hole with sheetmetal, welded it, and ground it down smooth.
In this pic you can see what we did about the inner roof panel. To keep the overall weight down we removed the center section of the inner roof skin, left about an inch wide flange, and bonded the flange to the outer roof skin with SEM panel bond. This stiffened up the roof considerably and cut the weight almost in half. Once the front and rear braces were tied into the existing inner roof skin, the roof panel was extremely solid with no twisting or flexing.
Old 11-18-2011, 05:18 PM   #9
theastronaut
For the latches, we had a pair of junk 80's Camaro T-tops that we took the mechanisms from. I built a bucket for the mechanisms to weld to, then welded the bucket inside the existing inner skin brace. I also had to cut the original rods and stems off and weld studs on so we could have removable rods.
I used 1/4" stainless rod for the pins and tapered the ends. The pins slide in 2" long, 1/2" outside diameter stainless spacers welded into the roof braces. Four more spacers were welded into the body of the car for the pins to lock into. The backside of the spacers in the body were capped off and the length of the pins in the roof were trimmed so that the end of the pins would bottom out on the pins in the body. That made the whole roof self-locate front to back, keeping the gaps even everytime the roof is installed.
One of the completed rods. For the final assembly, we used nyloc nuts and nylon washers to keep the linkage smooth and free from rattles.
Final shaping of the front brace. The ends needed some metal added on to cover the seal completely.
These shots show the front brace welded in. I also boxed in the existing side braces. I didn't get any pics of it but I later fully welded the bracing and boxing before doing the bodywork. The rectangle openings are access holes to be able to install/remove the latch pins and linkage.
Old 11-18-2011, 05:46 PM   #10
theastronaut
After doing the bodywork I masked it out and primed the front and rear roof pillars with Slicksand. I also primed the dash top so we could paint it.
After blocking and painting the dash top. I had to weld up a hole that was cut through the original speaker hole; the owner wanted it shaved instead of adding the speaker grill back in.
Primer blocked and ready for another round of priming and blocking.
I also made a pair of windshield garnish moldings using the original post covers and two upper moldings welded together to cover the width of the w/s frame. I split the upper moldings in half, made corner peices to fill in the missing spot between the upper and post covers, and welded it all together. They got bodyworked and painted to match the dash top. Shown here mocked up with the rubber seal.
Old 11-18-2011, 07:39 PM   #11
Indian113
Indian113's Avatar
Wow!! I'm impressed with the work you have done,I think it's going to be a 1 of a kind and very nice.
Indian113 is offline   Reply With Quote
Old 11-18-2011, 08:53 PM   #12
entourageguy
Yellow truck club
entourageguy's Avatar
Wow very impressed!
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-18-2011, 09:01 PM   #13
70-Shorty
that is some seriously b!tchen metal work.....very nice craftmanship sir! Only one thing that sticks out to me would be re-fabbing a better/custom roll bar top hoop and hide it (as in rearward what maybe 4-5") behind your excellent work. Tuck it in nice so it almost disappears....
Wish i had your skillz on the metal work.
Ontario CA•70 Chevy Shortbed Fleetside C-10
71 Chevy Longbed Fleetside C-20 (sold )
63 Chevy II Nova SS
02 Ford F-150 Harley-Davidson supercharged 5.4
2000 Harley Roadking Hot Bike Baggers Mag Shoot
http://s263.photobucket.com/albums/i...oot/?start=all
some truck lettering & flame jobs
http://www.flickr.com/photos/4950319...7602894916215/
70-Shorty is offline   Reply With Quote
Old 11-18-2011, 09:38 PM   #14
CAL 58 GMC
CAL 58 GMC's Avatar
Very nice work man! I think GM should have done a targa top on the new Camaro myself.
CAL 58 GMC is offline   Reply With Quote
Old 11-18-2011, 10:21 PM   #15
theastronaut
Thanks dudes!! 70-Shorty, I definitly agree about the main hoop being moved back so it would be hidden. It was already in the car when the owner brought it so we had to live with it.
I'll post some more pics for you guys once I get back to my computer.
Old 11-19-2011, 06:17 PM   #16
theastronaut
With the front and rear braces in place, I was able to test fit the roof and fine tune the front and rear gaps with 1/8" welding rods welded to the edges and ground down to even out the gap.
With the roof off you can see holes of the stainless spacers that I welded into the w/s frame and rear roof pillar for the latches to lock into. The back of these spacers were welded up solid so that the latch rods would bottom out in the spacers. The rods were trimmed to just the right length so when they are bottomed out, the roof would be centered in the opening front to rear, keeping the gaps even.
The inside garnish moldings painted.
With all of the metal work done, the roof was bodyworked and primed. I blocked and primed it a couple times to get it straight. The owner had a paint shop already lined up to paint the whole car but wanted us to go ahead and paint the inside of the lift off roof so it could leave fully assembled and working. I finish welded the inside braces and original side channels, then bodyworked and primed the underside. It got blocked and primed again, then painted to match the color code provided by the owner. Not shown in the photos, but we also reworked the roof rail seal/channel and shaved the factory window opening molding.
Here's the pics of top in primer. We still had to install the front and rear glass, the complete dash, and the roof rail channels and seals.
Dead even gaps front and rear.
For the underside of the roof, I sprayed the center section semigloss black, then masked the center out and painted the edges silver.
Unmasked with one of the windshield garnish moldings.
Reassembled with polished latch pins.
Old 11-19-2011, 06:24 PM   #17
project 67 sub
project 67 sub's Avatar
sweet
project 67 sub is offline   Reply With Quote
Old 11-19-2011, 06:41 PM   #18
theastronaut
Originally Posted by project 67 sub View Post
sweet
Thanks!!
Old 11-19-2011, 06:25 PM   #19
theastronaut
And a few pics right before the owner picked it up.
Old 11-19-2011, 06:45 PM   #20
project 67 sub
no problem, you deserve the compliments for the great work you did, and fixing the previous work as well
Old 11-19-2011, 09:07 PM   #21
MR FBDY
MR FBDY's Avatar
very nice work!
I am a long time Camaro guy and this is one of the best custom jobs I seen done to a second gen Camaro. Kudos to you.
MR FBDY is offline   Reply With Quote
Old 11-19-2011, 09:44 PM   #22
Pop's C-10
Pop's C-10's Avatar
That looks killer
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 11-19-2011, 10:55 PM   #23
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Very nice. I wanted to do that to my '78 too! I've seen one other on the road many years ago, in Houston.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-20-2011, 04:18 AM   #24
dammitmitchell
the pollock
dammitmitchell's Avatar
dude.. i was linked this from www.nastyz28.com.. those guys have a thread going about your thread here.
http://www.nastyz28.com/forum/showthread.php?t=228205
nice work man. can you tell us what you charged for this?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-20-2011, 10:28 AM   #25
theastronaut
Thanks for that link! I'm glad the camaro guys like it!!
IIRC, we charged around 10 g's. That included fixing the bad roof skin seams (inner and outer), cutting and repositioning the front and rear w/s openings to fit the glass, all the fab work on the roof, the bodywork and paint, new front w/s installed, used rear glass that we buffed to look like new, bodyworking and painting the dash, installing new door hinge pins and adjusting the doors and side windows, modifying the roof rail moldings and seals, shaving the side window roof trim, and reworking the quarter panel/door jamb area due to poor previous repair. I'm probably missing something but that's the things I can think of off the top of my head.
Starting with a clean roof would make the job much easier/quicker and less expensive if we built another one.
