VIN Oddity
Other than being screwed instead of riveted. Is the fact that there is a C and a K in the VIN odd? Thought they had one or the other to designate 2 or 4wd
Posted via Mobile Device |
Just a car guy
Re: VIN Oddity
Sounds odd. Screwws are scary as well.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
Re: VIN Oddity
![]() Posted via Mobile Device |
Re: VIN Oddity
Big, In 1972 the General added a C or T to the front of the Vin number. C is for Chevrolet and T is for GMC.
CHEVY/GMC VIN DECODERS |
Moderator
![]() Join Date: May 2007
Re: VIN Oddity
Run.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: VIN Oddity
Ok, adding the C in front would make sense, other than this is a 2wd with rear trailing arms with the crossmember riveted to the frame.... If it was a 2wd conversion wouldn't it have leaf springs?
Junior Member
Re: VIN Oddity
Oh Boy! Screws holding the VIN tag on!? Here we go....
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
Just a car guy
Re: VIN Oddity
What kind of vin tag is that????
Where in the truck is that located?
Re: VIN Oddity
It's on a '72 Blazer
![]() Join Date: Nov 2007
Re: VIN Oddity
Looks like the GVWR plate in the door jamb.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Just a car guy
Re: VIN Oddity
Does it match the frame stamp? I bet not. I would avoid it at all costs.
Re: VIN Oddity
Out of state, can't verify. last thing I want is DMV issues
Just a car guy
Re: VIN Oddity
Then stay away.
![]() Join Date: Jun 2010
Re: VIN Oddity
#15 |
Just a car guy
Re: VIN Oddity
#16 |
Re: VIN Oddity
Man, I really wanted this thing, but looks like my instincts may be right... thanks guys
#17 |
Re: VIN Oddity
Don't get too excited yet. Check the frame numbers and see if they match. Two things could be happening here:
1) All Blazers were known as K5's - regardless of 2wd or 4wd. Did this follow with the K or C in the VIN? I don't know, but someone else on here probably does. 2) If it is supposed to be CC for 2wd even though it's a Blazer, it is possible the factory screwed it up. Maybe it was the end of a Friday and the person stamping the VIN plate got it wrong. Check the numbers on the frame and see if they match. If the frame numbers don't match the VIN plate numbers, you have a reason to get excited.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#18 |
Re: VIN Oddity
Might want to check the local laws. Here, if the vin has been tampered with in any way (even if original and just replaced rivets with screws), it can be seized by the police and operator charged with a misdemeanor.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#19 |
Re: VIN Oddity
The screws would scare me right out of the deal. If the VIN tag and the frame stamp match then it might be that when the body was painted the tag was removed without thought on how it would be reattached (happen more than one would think). Some people will do things like pull a VIN tag to paint (the body might be off another Blazer) and then just screw it back one thinking that is OK. If it is a 1972 Blazer then the C first digit would be for Chevy, and like 71swb4X4 said the Blazer's could all be K for the second letter even though it is a 2wd.
I would go over it with a fine tooth comb if my heart was set on it, then get the correct rivets to attach that tag before I tried to take it to the local DMV. BTW original style rivets can be bought, they are found in Hemmings.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
#20 |
Re: VIN Oddity
I've seen the CK on there before. Don't let that scare you.
I had to rivet my vin tag back on when I replaced my cab. I had an all original, decently optioned truck but it was rusty. I got a super nice, all original metal cab and put it on, and riveted my original Vin tag to it. So my frame vin and gvwr tag match. I even have the original glow box door with the correct vin. Just look at it closer, there might be a good reason someone had to do that. |
