11-17-2011, 10:36 AM | #1 |
how do i know what transmission i have?
the truck is a 1963 Chevy c-20 3/4 truck. it has the 4 speed with granny first gear. i was wondering who mad the transmission, Muncie, Saginaw, etc. thanks
11-17-2011, 10:58 AM | #2 |
Senior Enthusiast
Re: how do i know what transmission i have?
It is most likely a Muncie SM420.
Here’s a link that's full of information regarding this transmission: http://www.novak-adapt.com/knowledge/sm420.htm |
11-17-2011, 01:20 PM | #3 | |
THAT IS AWESOME!!!! i did not know it had a PTO port. |
11-17-2011, 12:06 PM | #4 |
I agree with what Markeb01 said, only real way to know is to find the casting numbers and run them
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-17-2011, 01:13 PM | #5 |
Yes more than likely it is the muncie sm420, assuming your truck is a 2x4, if it is a 4x4 its more than likely the sm465...bascilly the 4x4 version of sm420
11-18-2011, 01:18 AM | #6 |
60-66 Nut
The SM465 didn't come out until the '68 model year. All light and medium duty GM truck 4 speeds prior to that were the SM420 in both the 2wd and 4wd.
11-18-2011, 03:29 PM | #7 |
"Where were you in '62?"
http://www.yearone.com/updatedsingle...nfo/muncie.asp http://www.5speeds.com/muncie.htm http://www.5speeds.com/muncie2.htm http://www.5speeds.com/muncie3.htm New Muncie 4 Speed Transmissions http://www.5speeds.com/newm22.html ((((Transmission Specs )))) http://67-72chevytrucks.com/vboard/s...d.php?t=390542 Online engine resources (casting numbers, calculators, etc.) http://67-72chevytrucks.com/vboard/s...d.php?t=382583 1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's http://67-72chevytrucks.com/vboard/s...d.php?t=327764
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 11-18-2011 at 03:35 PM. |
11-18-2011, 08:09 PM | #8 | |
11-17-2011, 01:17 PM | #9 |
thanks for all of the info. ive always wondered what transmission i had. aint thought about running the casting numbers, ill try that.
11-17-2011, 05:13 PM | #10 |
took mine to a local shop to have mine identified. he thought it was either a muncie or new process. turns out its a borg warner t18.
