11-17-2011, 09:53 PM | #1 |
31x18x15
ok i got a 64 fleetside an i got a guy im going to trade for some 31x18x15 mickey thompson sportsmans an was wondering how hard is it going to be to tuck them under the bedsides with the airbags i want to use on my truck. was goin to use the stock trailing arms if possible. also want to get about as low as possible dont have to lay rockers
11-18-2011, 12:06 AM | #2 |
Re: 31x18x15
No advice
Posted via Mobile Device |
11-18-2011, 11:46 AM | #3 |
1961 crewcab
Re: 31x18x15
check out 1bad62sprostreet build thread, I think he might be using those...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-18-2011, 12:01 PM | #4 |
Re: 31x18x15
I looked but I think he has the 31x15x15
11-18-2011, 11:04 PM | #5 |
Re: 31x18x15
Thats what I am running on my 66 stepside.[IMG]
11-18-2011, 11:43 PM | #6 |
Re: 31x18x15
do you have any pics of rear frame did you have to narrow the rear or is it stock rear
11-18-2011, 11:59 PM | #7 |
Re: 31x18x15
Yes I did narrow the frame and the rear can't recall how much off hand its been a while since it was done. The wheels are 15x14 with a 4" back space.
11-19-2011, 12:18 AM | #8 |
Re: 31x18x15
think you can throw a tape line on it maybe tomorrow
11-21-2011, 11:07 AM | #9 |
Re: 31x18x15
I won't be around it till after Thanksgiving but I would be happy to then. What I done when I narrowed mine was buy the wheels and tires so I had the correct measurements then I narrowed the frame for the clearance I wanted around the tire. Once I had the wheels and tires fitting under the fenders like I wanted then I measured from the bolt surface of each wheel to determine the width of the rearend.
11-21-2011, 05:19 PM | #10 |
"Where were you in '62?"
Re: 31x18x15
I'm running Weld Racing Draglite 90-Series Wheel 15 x 12. Covered with Mickey Thompson Sportsman Pro Tire, 29x15.50-15LT with tubes inside. 58 Ford Wagon 9” Rear End (Axle Length 57.25 inches) http://www.jegs.com/i/Mickey+Thompson/672/6558/10002/-1 " There are the Little Thickfatty's - Badinkadink " " The Badonkadonk - 33'' x 22''R - 20LT " Project: "Full Metal Yellow Jacket" Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=321173 https://skydrive.live.com/redir.aspx...D55CFC6D79!365 Pro Street Trucks/Cars pics!!! im in love with the fatty tires!! http://67-72chevytrucks.com/vboard/s...d.php?t=388977 31'' x 18.5'' - 15''LT http://www.jegs.com/i/Mickey+Thompson/672/6562/10002/-1 List of Mickey Thompson Sportsman PRO Rear Tires http://www.jegs.com/webapp/wcs/store...itemPerPage=90 List of Mickey Thompson Sportsman S/R Radial Rear Tires http://www.jegs.com/webapp/wcs/store...0002&N=0&Nty=0
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
11-22-2011, 08:51 AM | #11 |
Re: 31x18x15
k thanks all
11-22-2011, 08:57 AM | #12 |
Re: 31x18x15
Not what you want but close. These are 29x20x15's on 20x13" wheels.
