11-18-2011, 11:31 PM | #1 |
Oil Pressure Gauge: Installation Help
I'm replacing an aftermarket Oil Pressure Gauge, back with an original. Need help on what goes where.
I've attached pics of AfterMarket v's OEM Aftermarket has red wire, black wire, oil tube. OEM: studs...hole????
87' R10 |
11-18-2011, 11:53 PM | #2 |
Junior Member
Re: Oil Pressure Gauge: Installation Help
The OEM just plugs into the cluster back plate like the rest of the gauges. There should be some metal u-shaped pieces that fit through the circuit board and into the square holes behind the gauge.
11-19-2011, 12:02 AM | #3 |
What keeps/holds the oil pressure tube into the oem Gauge? The aftermarket has a nice fitting, with threads, keep tube in place.
87' R10 |
11-19-2011, 12:14 AM | #4 |
Junior Member
No tube. The oem uses an electric sender.
11-19-2011, 12:24 AM | #5 |
Okay so red wire, and black wire...am I missing a third wire?
87' R10 |
11-19-2011, 12:43 AM | #6 |
Junior Member
No wires. The black and red on the aftermarket gauge are for the light for the gauge. The oem runs off the circuit board on the back of the cluster.
Pull your temp gauge and you can see how it connects. |
11-19-2011, 01:47 AM | #7 | |
87' R10 |
