1961 crewcab
speedo cable adapter?
put a 79 trans am turbo 350 in my 63 chev truck.... what do I do to make the speedometer work? the 63 cable bolts up, but does not spin,or connect with the 79 transmission gear...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: speedo cable adapter?
I`ve read that some models in the GM line up used a adapter...why I`m not sure, but this may be one case.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Senior Enthusiast
Years ago I had a Super T10 4 speed from a1982 Pontiac and it had a weird adapter mounted for the speedo cable. I ended up replacing the tail housing and eliminating the adapter. I don’t know if this was common to Pontiac automatics or was something unique to the factory 4 speed. Here are the only poor quality photos I have showing the adapter:
You may have to change out the speedo gears.
[QUOTE=markeb01;5019430]Years ago I had a Super T10 4 speed from a1982 Pontiac and it had a weird adapter mounted for the speedo cable. I ended up replacing the tail housing and eliminating the adapter. I don’t know if this was common to Pontiac automatics or was something unique to the factory 4 speed. Here are the only poor quality photos I have showing the adapter:
` sure that wasn't just a ratio adaptor? ron |
1961 crewcab
my main problem is ,is that the cable is the same size, but the pontiac cable sticks into the gear about an inch farther than the chev.
the top of the pontiac cable clips on, wheras the chev screws on, so that won't work at the speedo head. I was thinking maybe there is something that would go inbetween the stock 63 cable and the th350.
#7 | |
ron |
Take a look at www.texasIndustrialelectric.com/speedo.asp. They may have something that will help. I'm dealing with a similar issue.
Posted via Mobile Device |
And or here Jon
http://www.transmissioncenter.net/sp...____va.htm#350
