11-20-2011, 10:03 AM | #1 |
1 Ton suspension swap
Do the same rules apply about swapping suspension on 1 tons as on the C10's?
I have a 67 C30 2WD that I want to upgrade to disc brakes, power steering, and a better rear diff. There is a 1987 donor available that I believe will work. Can anyone confirm this for me? |
11-20-2011, 12:22 PM | #2 |
Re: 1 Ton suspension swap
Yes, same guidlines apply. The rear might be a little different based on the width between the leafs of 67-72 DRW trucks vs 73-87's.
11-20-2011, 05:40 PM | #3 |
Thanks!
