11-20-2011, 08:15 PM | #1 |
Show us your crayon marks
So what's up with these seemingly random marks we find under the hood and on our firewalls and elsewhere on our trucks. What do they mean? Who put them there, and exactly when? Maybe if we compare a whole bunch of them a pattern might show, or at least some similarities may become evident.
So, if you got some production line scribbling somewhere on your truck, lets see it. Who knows ..we may learn something. Below: Yellow crayon underside of hood on my '66. Also, on the same truck below the right cowl extension is what looks like the signature (in wet paint) of the guy who shot the color? |
11-20-2011, 08:33 PM | #2 |
Re: Show us your crayon marks
I will get some of mine soon. In the meantime oem4me, it would be awesome if you could take many, many pictures of your truck to aid others in assembly for originality. You may have the best original truck in exsistence. This obviously would be at your discression. But there may may not be any better truck to go by like yours. Do you have an online picture account somewhere that you could do this? If so that would be great.
Thanks Tom |
11-20-2011, 09:24 PM | #3 |
Normally they relate to build sequence numbers (put there by line workers, in an attempt to keep everything in order) or inspection marks, indicating the item has been checked and approved - or - checked and repair is required.
Most large component assemblies, like tire/wheel assemblies, seats, rear axle trim and driveshaft, front suspension assemblies and engine/trans trim are built up in remote areas of the plant and then conveyed to the main line. It is essential that these items remain in order; if not, then not only is the affected vehicle messed up but everything upstream is messed up too. They could also be lunch calculations, love notes, or ciphers for their "bookie". Anything is possible. In the case of the two pictures you've presented - they are not like anything I've seen before on a vintage vehicle. The hood picture seems to indicate perhaps a bank of 10 special parts, and that your's was number 10 in that series (maybe a material tryout of some kind). And - the cowl photo sure does look like somebody's signature. Never seen that specific one before but I wouldn't put it past someone to do that. In the Pontiac world there was a lady named "Linda" that became quite famous for signing the backside of the glovebox doors that she put together. Here's mine: I followed my truck down the line (drove it off the line myself) and didn't remember this, but it was apparently build number "87" for that day: They are no longer there but I would have expected to find a number 87 on the rear diff cover, on the inside of one (or more) tire/wheel assemblies, on the side of the frame and maybe written on the engine somewhere, all in an attempt to keep the flow of material in order. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-08-2016 at 11:24 AM. |
11-21-2011, 06:20 PM | #4 |
Two more "signatures" found in the same place, but on my 65 Suburban. To me, none appear to be from the same hand. Both trucks are from the Fremont CA plant.
11-22-2011, 09:13 AM | #5 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-11-2011, 08:39 PM | #6 |
#329 is written on my K20's firewall above heater, behind dash, on gas tank, on top of bell housing. It also appears to be stamped into the top edge of the firewall above the power brakes.
72Kay20 Bel Air, MD 1972 Hugger Orange K20 LWB 350, 4wd, 4spd Sm465, Dana 44, HO52 Other Toys 69 Cortez Silver Z28 86 White Buick T Type |
11-21-2011, 12:45 PM | #7 | |
Now all I need is some quality time with my truck and a camera (which is not so easy to find these days). Thanks for your patience on that one. On another note, even as well preserved as my 66 is, I know there are a lot of other trucks out there that are even better. They just belong to people that are not members here, or just prefer their privacy. Example: Recently, a 62 longbed showed up out of nowhere with less than a thousand original miles, virtually unused and in near perfect condition. They are out there. Last edited by oem4me; 11-21-2011 at 08:44 PM. |
11-21-2011, 10:06 AM | #8 |
Her's the only one I could find on my '65......
_____________________________________________ Ray All my life, I've been told I'm a "Bad Influence" |
11-21-2011, 10:13 AM | #9 |
Only thing I've really noticed on my stuff was sometimes the VIN or part of it is written on the firewall, but the only thing consistent I've seen was the color-"ivory" written on my 64 & two-tone on my other 64's firewall, seen many others with the color written on the firewall. My theory is many cabs were painted white, then body color added to the lower part for the two tones.
11-21-2011, 10:52 AM | #10 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-15-2015 at 07:36 AM. |
11-21-2011, 12:52 PM | #11 |
quote:Recently, a 62 longbed showed up out of nowhere with less than a thousand original miles. Virtually an unused truck in near perfect condition. They are out there.
wow, thats awesome. Yea when you get time for yours that would be sweet. |
11-21-2011, 01:02 PM | #12 |
Id love to find an original truck with only 1,000 miles, bad thing is I use it like my daily driver. I just personally enjoy driving my vehicles no matter what year or mileage is on them.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-21-2011, 07:31 PM | #13 |
I need to get my camera to the shop to take some pictures of my 63. It has all the crayon marks still. My 64 had them as well, but I got a little too aggressive when cleaning the fire wall and you can barely read them. My 63 has them above the fire wall. Maybe bc the firewall is fawn??
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air. |
11-22-2011, 04:31 AM | #14 |
Very interesting thread. Waiting on more pics.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
12-13-2011, 10:00 AM | #15 |
oem4me your truck was built early april . last truck built in march was 156938 take care mike
12-13-2011, 12:26 PM | #16 |
12-13-2011, 07:32 PM | #17 |
over the years of collecting i found a guy that had the info. i have it for all the plants i can tell what month a truck was built . not the day . on my 66 the build sheet says schedule build date 10-29-65 . but i think my truck was built in nov of 65 last truck made in oct is 114952 . each plant had used there own number system mikem
12-13-2011, 11:37 PM | #18 |
Hey Yelmer how bout #159704 `64 model....chevy ...by the way do any of the crayon marks match up with an RPO...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
12-13-2011, 11:46 PM | #19 |
i need to know what plant ?
02-24-2022, 08:32 AM | #20 | |
Check The Champ, Demonstrator
RPO system started in 63. If you look at the order sheet and your truck Crayon markings you'll notice the numbers jive without the letters before them
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
12-16-2011, 03:34 PM | #21 |
That is correct; there is no correlation between plants relative to VINs or daily build sequence numbers.
These Fremont trucks are crackin' me up! Apparently the guys in the paint shop were pretty creative... K
12-14-2011, 04:45 PM | #22 |
Grandpa in the rustmobile...
mine has a letter scratched into the original paint behind distributor on firewall
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-14-2011, 08:58 PM | #23 |
Interesting thread here...These are mine. The yellow "Crayon" ones are on my hood (along with a similar marking that indicated the truck got new tires in 1979 - Dealership maybe? ) The other marking is similar to 70shortfleet's, same spot...didn't know it was there until I saw this thread and went and looked. My truck was made in Fremont, November '71. The "329" marking is interesting as it's the same number as 72kay20's...
12-14-2011, 10:19 PM | #24 |
GMC's n H.D.'s too!
I HAD this one under my hood. The hood has gone to live with another member.
This one is on the firewall behind the passenger inner fender. It is continued below the heater. This one is behind the distributor on the firewall. I kind of rubbed some of it off (OOOPS) trying to make it legible for the picture. This one is on the front of the cowl, dead center. I didn't even know it was there until I was sitting in the engine compartment trying to clean the one behind the distributor. |
12-14-2011, 11:00 PM | #25 |
I saved mine and after new paint I was able to go right back over the faint original grease pencil under the paint. It was a loaded 66 283 powerglide with factory air ps and pb and tinted glass.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
