Old 11-21-2011, 03:29 PM   #1
KVB
Bed bolts
Hi,
I have a 1965 GMC short wide. I am in the process of doing the box floor with new Southern Yellow pine. When I took the bed apart and removed the rails, I found that I had Ribbed neck carriage bolts, sometimes called Track bolts. I am having a hard time finding these, as they are not a very common bolt.
First, has anyone else come across this type of bolt in thier box, and Second, were you able to find replacement bolts. If yes, where?
I am considering buying new strips and bolts, but the originality aspect intrigues me.
Any info would be greatly appreciated.
Ken
Montreal
KVB is offline   Reply With Quote
Old 11-21-2011, 03:58 PM   #2
1963c-10
1963c-10's Avatar
Re: Bed bolts
I got my bolt kit from Mar-K. I cut out the orginal bed inmy 63 and found standard carriage bolts, didnt find anything ribbed.
1964 Short bed trailer
Old 11-21-2011, 06:12 PM   #3
Clyde65
Clyde65's Avatar
Re: Bed bolts
Ribbed are usually for the strips that arent punched with square holes. If your getting strips from a vendor, ask for the punched ones and get the carriage bolts.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-21-2011, 07:57 PM   #4
tomfg
Re: Bed bolts
Ken, When I took apart my 64 long bed, it had some "star shaped holes" punched in the carriage bolt washers. Can't remember at the moment if the carriage bolt shanks were star shaped as well, or just the regular square type.
tomfg is offline   Reply With Quote
