Old 11-22-2011, 06:34 PM   #1
SS From the "Wood"
SS From the "Wood"'s Avatar
Bucket Seat Mounting '84 3+3 CC
I'm in full on research mode for a project I hope kicks off 1st of the year. Fortunately for me, someone already started it, but I plan to finish it, although it's still going to be a full frame off build.
I'm looking at swapping the front bench in favor of a set of late model chevy buckets (integrated seat belts) into the cab, and was wondering if anyone has done it or knows what mounting options work best? Even if I had to fab something up to mate to the cab floor, I don't think it would be too difficult. My preference would be to find a kit to retrofit however. I see that Corbeau makes a seat bracket kit, but don't know if it bolts to the seat frames I'll be getting. Any insight would be appreciated!
-shannon
SS From the "Wood" is offline   Reply With Quote
Old 11-22-2011, 06:43 PM   #2
notyo_cheez
Re: Bucket Seat Mounting '84 3+3 CC
For buckets you'll have to tack weld a riser with a nut on it so the inner seat rail can have something to bolt to, if not you'll put stress on the cab floor and the sheet metal will crack.
notyo_cheez is offline   Reply With Quote
Old 11-22-2011, 06:56 PM   #3
SS From the "Wood"
I will probably just have to keep my patience in check, and make adjustments "on the fly" when I actually have the truck in my possesion.
Old 11-22-2011, 07:21 PM   #4
SCOTI
SCOTI's Avatar
Many Suburbans came w/front buckets & a console. They have the brackets required for the trans tunnel side. They're spot welded to the floor though & will take some persuasion to remove if you have to do it manually.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-22-2011, 11:48 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
my burb
look for these...worth weight in gold!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-22-2011, 09:25 PM   #6
yousesteers
I put seats from an 05 in my 84 CC they were the 40/20/40 bench seat but I would guess the seat mounts very much the same way. I lowered the floor boards 3 inchs basically took the hump off both sides Wish I had went lower Then I put a pitce of 1/4 by 4 flat iron bolted to the bottom of the seat and then bolted that through the floor board and put some big square washers i made on the botttom side of the cab worked pretty well I used all the rails and power stuff off of the 05
yousesteers is offline   Reply With Quote
Old 11-23-2011, 01:14 AM   #7
kwin
kwin's Avatar
That is what I did, essentially. I cut the floor down so that the floor behind the front seat runs straight to the ribbing that is between the bumps in the floor.
I cut them down built flanges to support the new top, built a top with beading for strength and ran 1/8 plate from the rear floor under the seat mounts up to the bump and on to the original front floor.
I plug welded the 1/8 plate to the floor and stitched it from the bottom.
Probably overkill but better that than too weak.
I used 2000 GMC seats and took off the 1" risers and like the way they sit.
Good luck.
Keith
kwin is offline   Reply With Quote
Old 11-23-2011, 02:09 PM   #8
SS From the "Wood"
Good luck.
Keith
Keith, do you have pics of your mod? Feel free to be a post whore here my friend!
-shannon
Old 11-23-2011, 05:13 PM   #9
kwin
kwin's Avatar
I haven't taken any, I was going to this afternoon, but I have never had any success posting photos to this site.
Ill try again.
Keith
Old 11-23-2011, 12:37 AM   #10
my4by2
my4by2's Avatar
One word of advise - if you get the Corbeau brackets - they'll need to be modified for the crew cab floor. I bought them & their Moab seats & they had to be modified in my 77 crew cab. Other than that though, they were high quality & worked out great!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 11-23-2011, 11:47 PM   #11
SS From the "Wood"
Just save em to ur desktop and attach to post (paperclip icon when posting new comment) like u would in an email. It won't show in ur post preview until after u submit post. Hope this helps.
Old 11-24-2011, 12:33 AM   #12
kwin
kwin's Avatar
I have no idea why it always causes me problems , I'm on several forums and it rarely works, maybe its a mac issue , maybe im just dense....
Kind of embarrassing for a photographer...
www.ramsaywinsor.com
Old 11-24-2011, 10:54 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
don't make them any bigger then 1024 wide or tall
I forget all the time,comes up "missing token".....I missed what lol?
mine are huge (4416x2480),i always have to resize, and crop for a closeup
i have a file ,say like (78 truck) inside it has all my pics,but also a file folder (78 truck(s)
for the smaller pics
after editing a pic, go, file, save as,
and the second smaller pic file is right there...to save it in
and post with those
John
Old 11-25-2011, 08:18 PM   #14
pig rig
pig rig's Avatar
I put bucket seats out of something in my crew cab and what I did was lay 1" squar tube across the floor, so it spanned from driver to passangers front and rear. and once I had the tub setting squar I made tabs that I bolted into the stock seat mounting locations then welded them to the 1" tube then I mounted the seats to the tube and I found a center councel I liked and I was able to mount it to the tubing also. THE nice part is I could unbolt the brakets and pull both seats and councel out as a whole
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-30-2011, 05:48 PM   #15
SS From the "Wood"
I hope these show up correctly...
This is what I'm hoping to end up with. Front buckets (integrated belts) w/ fold down center console, and with a little luck, I'll be able to use the 2nd row too in the rear so pattern matches.
Anyone able to shed more light?
-Shannon
Old 11-30-2011, 06:15 PM   #16
yousesteers
-Shannon
Exactly what I have in my 84 CC out of an 05 silverado watch my build thread as I will try to get pictures of them up there tonight or tomorrow
