Old 11-24-2011, 11:13 PM   #1
Reziel_1983
Reziel_1983's Avatar
My 377 build.
Well I put my 377 in my 83 lwb today and I figured I would make a thread with some pictures in case anybody cared. Started with a 400 sbc 4 bolt main that was really gross looking. Got the block machined, and put the spacers, bearings, and crankshaft in.
Here are the specs on the engine:
400 Small Block bored .030 over,
destroked with a 3.48" stroke steel Crank,
dish top speed pro pistons,
Comp Cams XE 268H Hydraulic Flat tappet camshaft & lifters kit,
493 casting number 400 sbc heads 1.94 intake and 1.50 exhaust 76cc with z28 springs,
Holley Street Dominator Dual Plane Intake Manifold,
Holley Street Avenger 670 cfm carburetor
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 11-24-2011, 11:15 PM   #2
Reziel_1983
Re: My 377 build.
Here are a few parts that I used.
Old 11-24-2011, 11:22 PM   #3
Reziel_1983
Re: My 377 build.
Got the pistons, timing chain, cam, and heads on here. Also here's one of the crank in that I forgot to post.
Old 11-24-2011, 11:24 PM   #4
Reziel_1983
Re: My 377 build.
Motor's all painted up and about to be dropped in! Here is the old motor as well. 350 with performer intake and a bigger cam.
Old 11-24-2011, 11:27 PM   #5
Reziel_1983
Re: My 377 build.
Engine is in!
Old 11-24-2011, 11:39 PM   #6
bustedknuckles
bustedknuckles's Avatar
Re: My 377 build.
Nice. How's it run?
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline   Reply With Quote
Old 11-24-2011, 11:55 PM   #7
Reziel_1983
Re: My 377 build.
Originally Posted by bustedknuckles View Post
Nice. How's it run?
Runs pretty good
Old 11-25-2011, 12:06 AM   #8
slugish
Slugish
Re: My 377 build.
Just a note Im certainly not an expert but Ididnt know they made 4 bolt mains on the 400 ci sbc. Learn something everey day .
Also probably another dumb question but what is the reasoning behind destroking a 400 . I have a 408 by the way .
slugish is offline   Reply With Quote
Old 11-25-2011, 12:08 AM   #9
Reziel_1983
Re: My 377 build.
Yeah I've heard that the 2 bolt mains for the 400 small blocks are actually better but I was on a budget and had to work with what I had :P.
Destroking a 400 to a 377 will give you higher top speed, but take the torque down a bit from what I've heard. I would probably rather have built a 406 but I got the block, a bunch of parts including a 3.48" stroke crank for 300$ and I was on a pretty tight budget so again, I had to use what I had
Old 11-25-2011, 12:19 AM   #10
Reziel_1983
Re: My 377 build.
Here's a video of it, I'll upload another when I adjust the carb/timing:
Old 11-24-2011, 11:39 PM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: My 377 build.
did you prime it with an oil primer first? and run break in oil this time?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-24-2011, 11:54 PM   #12
Reziel_1983
Re: My 377 build.
Yeah, I primed the oil pump. And no, we just used the delo 15w-40... it seemed to do okay.
Old 11-25-2011, 12:18 AM   #13
INSIDIOUS '86
Re: My 377 build.
well i would have run some zinc additive to but if it lasted its first ten mins without flattening the cam then your set
Old 11-25-2011, 12:34 AM   #14
INSIDIOUS '86
Re: My 377 build.
http://67-72chevytrucks.com/vboard/s...d.php?t=466886
post that vid in there! add your exhaust specs
Old 11-28-2011, 09:03 PM   #15
Reziel_1983
Re: My 377 build.
Adjusted carb and timing today... I'm not sure if it's perfect yet but I'll post a video tomorrow of it.
Old 11-29-2011, 11:31 AM   #16
rayfinseats
Re: My 377 build.
2 bolt 400 block is probably stronger but. Anyway I would recommend vortec heads !!! It should be a pretty strong motor but Vortec heads would make a big difference in power on a budget. I wish I had that engine
rayfinseats is offline   Reply With Quote
Old 11-29-2011, 12:39 PM   #17
Hotrodrobert
Re: My 377 build.
I don't see any info on those heads but they are probably 74-76cc chambers and with your stroke and pistons that is about 8.4:1 compression ratio.
You can run almost any gas you can find but I like power.
The Vortec heads recommended by Rayfinseats would be a huge improvement. They are cheap to buy but you would need a different intake so that is more money, but that would be about 9.4:1 compression ratio but the superior chamber design would mean you probably could still run 87 and the power increase would be OVER 50!! with BETTER fuel economy!!
74 Longbed
76 Shortbed
87 Shortbed
66 Corvair Turbo
62 Chevy II Turbo 6
Hotrodrobert is offline   Reply With Quote
Old 11-29-2011, 01:35 PM   #18
Your41Plague12
Your41Plague12's Avatar
Re: My 377 build.
If you get the Vortecs, make sure you drill the steam holes in them. Other than that, I say go for it.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-29-2011, 02:00 PM   #19
Reziel_1983
Re: My 377 build.
I probably would have bought the vortecs but I was really tight on money, barely made it with what it has now! I might get some performance heads for it down the road sometime.
Old 11-29-2011, 04:33 PM   #20
Reziel_1983
Re: My 377 build.
Carb and timing is set.
Old 12-01-2011, 11:48 PM   #21
slugish
Slugish
Re: My 377 build.
Originally Posted by Reziel_1983 View Post
Damn tose thumper cams sure do sound bad. Iwas about ready to get on e myself but a number of techs advised I would get better overall performance with a xe 274 which I ended up getting . Who knows , we,ll see once I get it in .
Old 12-02-2011, 12:14 AM   #22
Reziel_1983
Re: My 377 build.
I don't have a thumpr, I have the xe 268. I might have gone with the thumpr but I read that they are all bark and no bite.
Old 12-02-2011, 12:47 AM   #23
slugish
Slugish
Re: My 377 build.
oh for some reason Ithought you said you had a thumper . Yea bark but no bite is what I have heard .
Ihave a xe 268 now & have boght the xe274
but my 268 sounds a lot tamer than yours ? maybe the exhaust
Ihave full lenghth headers > 3 in. collecter into one flowmaster , 3 in in & 2- 2.5 's out dumped behind rear wheel
Old 12-02-2011, 12:49 AM   #24
slugish
Slugish
Re: My 377 build.
Ihave full lenghth headers > 3 in. collecter into one flowmaster , 3 in in & 2- 2.5 's out dumped behind rear wheel. I WONDER if Ihad true duels would it sound better.
Old 12-02-2011, 01:23 AM   #25
INSIDIOUS '86
Re: My 377 build.
have the small thumpr in my truck, alot of bite for a 420 hp 377
have to add 1.6 ratio rockers to the exhaust to make it more like a single pattern cam, really wakes up the cam, not to mention if you set the timing curve right,
im sure if i had some better flowing heads and intake i would be at about 500 hp and great streatability
bark with bit i tell you, the bigger cams for thier size do not deliver i admit, even then if your going to put a massive cam in why go thumpr?
