11-25-2011, 01:30 AM | #1 |
71 3 speed column??
I have a quick question. My truck was originally a 3 speed manual truck and I am putting a th350 in it. I wanna know if I can use the 3 speed column to actuate the linkage on the turbo 350??
11-25-2011, 08:40 AM | #2 |
Re: 71 3 speed column??
no. It would be a perfect time for a tilt wheel conversion. good luck
11-25-2011, 06:09 PM | #3 |
Thanks.. Cant afford a tilt yet but I would love to find one as I am a big guy. So no one has converted one and what is the difference between a manual and auto column??
11-25-2011, 06:42 PM | #4 |
The shifter tube on the auto has one lever that moves the linkage whereas the manual colomn has two levers that has a "ramp" [for the loss of a better word] that is between the two levers that work the linkages . Stand at the front edge of your truck and have someone work thru the gears and you will see what I mean by it not working. The auto almost has an up and down motion and the stick has a radial one
11-25-2011, 07:33 PM | #5 |
I am a Referee of life.
Find a stock auto column.They're not expensive and fairly common.Then search on the site and do the shortened column mod.You'll gain some room for Big Guy's and have a shifter that works correctly.Here's a link.
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
