Old 11-25-2011, 07:40 PM   #1
pig rig
pig rig's Avatar
steering box question
I've got to do something with my seering box it leaks like a sieve. so I'm needing to pull it and put seals in it. this is the only thing I've never tore into before and I'm having problems finding any info on them
so is their anything special I should watch for when pulling the box apart? I dont think I'll pull the top plate off with the gear adjustment so the only seals will be the ones in the ends
anyone got a link to an exploted view of a box that would realy help
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 11-25-2011, 08:33 PM   #2
jimbonice
jimbonice's Avatar
Re: steering box question
My 1977 C30 was leaking like a sieve out the sector shaft and input, and I've replaced seals in the past but at some point I figured a 34 year old box might need to be replaced. Price was pretty good at rock auto so I just bit the bullet and replaced it. Having a tight steering box did illustrate the other deficiencies in my balljoints and tie rods though.
It never ends.
jimbonice is offline   Reply With Quote
Old 11-26-2011, 08:57 AM   #3
homemade87
I have done the same thing you have talked about. It did not last long before they leaked again ( 10 to 12 months). I guess they get to a point the bearing surfaces get enough wear that they move around so much they just wear the seals out again. I just put another on from the local parts store. Problem solved.
homemade87 is offline   Reply With Quote
Old 11-28-2011, 02:35 AM   #4
pig rig
pig rig's Avatar
yeah so I got the truck up in the air where I can see it and its the seal behind the rag joint called the parts store and they wanted $350 for a new box (yeah thats not going to happen) and 40 for the seal kit so I'll be getting a crash course on stearing boxes this next week
Old 11-28-2011, 04:26 AM   #5
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Here's an article a friend of mine wrote: http://www.fourwheeler.com/techartic...d/viewall.html
I have a rebuild kit coming next week and will be starting mine soon...
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 11-28-2011, 08:02 AM   #6
homemade87
I am surprised it was that much. I bought one for my 82 and it was only 125.00. It was a rebuilt one from cardone.Must be some diffrences in the years.
Old 11-28-2011, 09:59 AM   #7
Stepper562
Stepper562's Avatar
Dang 350! I bought mine for 120 from clarks, lifetime warranty.
Stepper562 is offline   Reply With Quote
Old 11-28-2011, 07:54 PM   #8
pig rig
pig rig's Avatar
yeah thats the price for a new one. one thing I didnt say is mine has a hydroboost on it
Old 11-28-2011, 09:58 PM   #9
donut
donut's Avatar
I've got the link Bad Karma posted bookmarked.
Careful on a re-seal. I resealed mine and ended up replacing the box anyway. As it turned out, in my case, those little ball bearings were wore. When rolled on a flat surface they appeared to be little footballs. Couldn't get the box adjusted so it was smooth after I put it back together. Oh well, if it worked I could have saved 100.00, instead I ended up replacing an almost 40yr old steering box. At least now I know first hand what the guts of a steering box look like.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
