Old 11-26-2011, 03:28 PM   #1
FLcustom10
So frustrated with this sending unit
I have 8 gallons of gas in the tank. That really should be enough for the gauge to register. It works perfectly when I take the sending unit out of the tank and lift the float with my hand. As soon as I put it back in the tank it goes to empty and stays there. It is the same result whether I have the unit grounded to the tank or if I use a separate grounding wire. I have proved to myself that the float will in fact float in a bucket of water. I'm about to decide that it just won't float in gas. Could it be hitting the side of the tank somehow and binding? I can tie a wire around the float and lift it and the gauge will register, but when I release it the gauge goes back to empty. Shining a flashlight down there it looks like the gas level is at least up to the first indentation in the tank.
FLcustom10 is offline   Reply With Quote
Old 11-26-2011, 03:41 PM   #2
1972RedNeck
1972RedNeck's Avatar
Re: So frustrated with this sending unit
I had to bend the new one to go in our '60 Chevy. It was a ways out of wack.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 11-26-2011, 03:59 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
When testing it did you put the lock ring on it? If not it may be a ground problem. Also if you reciently had your cab painted your tank may not be getting a good ground.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-26-2011, 04:09 PM   #4
FLcustom10
I think I've convinced myself it's not a ground problem. As soon as I lose contact with ground the gauge swings to past full. I'm going to go ahead and add 5 more gallons of gas and see what that does.
Old 11-26-2011, 04:33 PM   #5
FLcustom10
OK. After adding 5 more gallons it is registering 1/4 full. I think I have about 13 gallons in there. I hate to screw this up, but I guess it already is screwed up. I guess I'll try bending it to where it registers just under 3/4 ??
Old 11-26-2011, 04:41 PM   #6
domeier
domeier's Avatar
Originally Posted by FLcustom10 View Post
:After adding 5 more gallons it is registering 1/4 full.
Dude: Your gas station is cheating you!
domeier is offline   Reply With Quote
