11-26-2011, 05:49 PM | #1 |
Rear discs install question
Hey everybody,
I just finished up installing new discs in the rear of my 64 swb. However, getting the calipers with pads on the rotors was a mess. The pads are so close, the rotors won't spin now. It is like the pads that came with the setup are just a little too thick. Has anyone else had this happen to them when installing discs? Also, any suggestions on how to get sme play? Thanks guys! Posted via Mobile Device |
11-26-2011, 05:58 PM | #2 |
Re: Rear discs install question
What I've always done is use the old pads and a c clamp to depress the piston. On the old ones When the pad wears down, the piston has to extend further to make up the slack. The c clamp method resets the piston and allows you to put in new full size pads.
11-26-2011, 06:01 PM | #3 |
I tried a c clamp, but the piston seemed to be all the way in. It is a brand new caliper and brand new pads...
11-26-2011, 06:17 PM | #4 |
Could have the rotors turned
11-26-2011, 06:22 PM | #5 |
11-26-2011, 06:30 PM | #6 |
what calipers are you using
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
11-26-2011, 06:38 PM | #7 |
http://www.ebay.com/itm/63-70-chevy-...5#ht_500wt_922
This is the kit I bought off eBay. They are gm calipers, but I am not sure specifics on them. In should also say it is just a rolling chassis at this point, no engine. Posted via Mobile Device |
11-26-2011, 06:43 PM | #8 |
C/10 junkie
According to the link that you posted it looks like those calipers are going to need what we call a "caliper retraction". That means that the calipers pistons are going to need to be "screwed" in. Anotherwords you can't just press in the caliper piston with a c clamp you will have to turn the piston clockwise, for most cars, at the same time you compress it in.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
11-26-2011, 06:47 PM | #9 | |
11-26-2011, 06:58 PM | #10 | |
C/10 junkie
11-26-2011, 07:07 PM | #11 |
[QUOTE=shawno72;5032083]Go down to your local Autozone or Oreillys and rent the tool for it. It should look something like this. What you do is line up the two little notches on the tool with the notches on the caliper piston and then just turn it in.
Awesome! thanks for your advice! Posted via Mobile Device |
11-26-2011, 07:21 PM | #12 |
C/10 junkie
Your welcome hope it all works out. You might want to look at your caliper pistons to make sure we are headed down the right path. Let me know how it turns out.
11-26-2011, 07:10 PM | #13 |
Guess it would be about the same idea
11-27-2011, 02:00 PM | #14 |
C/10 junkie
Well did it work??
11-27-2011, 03:16 PM | #15 |
I wish I had better news. The pistons were all the way in. I used the bench grinder on one pad and shave just a little off and helped a lot. I guess I will do that to the other side and have pretty tight brakes for a while....
11-27-2011, 04:41 PM | #16 | |
C/10 junkie
11-27-2011, 04:45 PM | #17 | |
11-27-2011, 06:27 PM | #18 |
C/10 junkie
No it won't be a bad thing to shave the pads down a bit, just watch that you keep the surface flat and don't leave grooves.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" Last edited by shawno72; 11-27-2011 at 08:55 PM. |
11-27-2011, 07:36 PM | #19 |
Post some pics of it
