Old 11-27-2011, 09:26 PM   #1
niterider65
niterider65's Avatar
Cool holes to fill in the on a step side bed
Ok this might be and easy one should i make plugs to weld up the holes
or can i just filll it in with wire welder ... if i us a plug who would make a hole punch to make small plugs any ideas would be great .
the holes im filling in are the holes that mounted the spair tire on the step.
one hole will be covered up the new step fender...
niterider65 is offline   Reply With Quote
Old 11-27-2011, 10:09 PM   #2
'63GENIII
'63GENIII's Avatar
Re: holes to fill in the on a step side bed
I would get a four square metal electrical box and knock out whatever slugs that you need. 1.50 at Home Depot. A little heavier gauge but it would work.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-27-2011, 10:43 PM   #3
jocko
jocko's Avatar
how big are the holes? Can't really tell scale in the pic. If they aren't much bigger than trim holes, then I'd just fill em in with wire (use a piece of brass as a backing plate so weld won't stick and will have a flat backside). But, for me, much beyond 1/4", I'd cut a plug.
Old 11-27-2011, 11:24 PM   #4
niterider65
im guessing i would say the bigger holes are 7/16 and the smaller hole is 3/8 ..
Old 11-27-2011, 11:58 PM   #5
jocko
jocko's Avatar
OH - in that case I would cut a plug for both.
