11-28-2011, 04:28 PM | #1 |
Spindal Question
does anyone happen to know the dimentions for a stock spindel on a 64 1/2 ton the reason im asking is because my truck seemed to have a lower stance then some of the same trucks ive seen on here. any information would be greatly appreciated
11-28-2011, 05:26 PM | #2 |
Re: Spindal Question
Show us a side pic, alot of these old trucks have sagging spring and wore out shocks. I put 1.5" drop springs on my truck and it only dropped 3/4".
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-28-2011, 05:42 PM | #3 |
What size tires are you running?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
11-28-2011, 05:51 PM | #4 |
the truck is no longer on the frame. i can probably get a picture of the spindel but thats about it.
11-28-2011, 09:04 PM | #5 |
If its the original drum brake spindle it would be the same as all original trucks I don't think you can get different height spindles for drums on these trucks.
but I may be wrong |
11-28-2011, 11:44 PM | #6 |
Resistance is Futile
My '66 had broken the last coil off in the spring pocket. I've seen a few others on here like that also.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
